Results 21 to 40 of 47
Thread: won't stay running
    Tuning Addict
    10,887
    12615136 is an old number, superseded by 19418810 (the current number). They interchange.
    Tuning Addict
    10,887
    Does it run if you put in the right linear/offset for the 1-bar sensor?
    Aug 2024
    Texas
    174
    I didn’t even attempt it I just went a got sensor. But everything seems to work well with a short run around the block.
    Aug 2024
    Texas
    174
    Wait a minute. I thought I already gave you good options for 2 bar maps? TMAP or IAT/MAP separate. With separate IAT get a 12615136. Linear/offset is 200/8.
    Fuel pressure is setup for non-referenced. Is that the reg configuration?
    Set Fuel>Transient>Min Fuel Mg to 0.005.
    i ran it and it seems to really thin out in power enrichment
    Banned
    Mar 2022
    Indiana
    4,289
    Idk. It should be coming out of PE at 70kPa, 51% tps. It's staying on during decel.
    Fuel matches commanded perfectly until the point where it should be coming out of PE.
    Maybe try the SD12 file I made for you instead of the FlexFuel one that cobbled code from like 3 different tunes? Apply the 2bar OS to it and modify necessary tables.
  6. #26
    Aug 2024
    Texas
    174
    same thing no change from what i can tell. you dont think we need to add more fuel to power enrichment?
  7. #27
    Banned
    Mar 2022
    Indiana
    4,289
    No. Those areas were mapped out with LTFT+STFT. Need to figure out why it's not coming out of PE.
  8. #28
    Banned
    Mar 2022
    Indiana
    4,289
    Disable Fuel>Temperature Control>COT.
  9. #29
    Aug 2024
    Texas
    174
    thoughts?
  10. #30
    Banned
    Mar 2022
    Indiana
    4,289
    That's more like it. First was taking care of PE. Now re-tune VE.
  11. #31
    Aug 2024
    Texas
    174
    which table do i use to tune the ve? do i use the gen3 ve eq 2 bar table? add the red and minus the green numbers? also with these injectors it seems peppy or very responsive.
  12. #32
    Banned
    Mar 2022
    Indiana
    4,289
    First make sure fuel data matches reg config. Vacuum referenced reg or not?
  13. #33
    Aug 2024
    Texas
    174
    no vacuum constant 58 psi I switched all the fuel data over to sd12
  14. #34
    Banned
    Mar 2022
    Indiana
    4,289
    Ok then make adjustments like you were saying. lmk if you need help.
  15. #35
    Aug 2024
    Texas
    174
    will tuning the supercharger be same?
  16. #36
    Banned
    Mar 2022
    Indiana
    4,289
    Yes, but you'll need to use a wideband for most of it. LTFT should be disabled and cleared when tuning the wideband portion NA or FI.
  17. #37
    Aug 2024
    Texas
    174
    that maybe where i messed up i was about to ask if i should turn off LTFTs and clear when doing this tune
  18. #38
    Banned
    Mar 2022
    Indiana
    4,289
    Fueling is looking pretty good. Keep at it. I enable LTFT for the narrowband portion. Disable for wideband because positive LTFT's carry over.
  19. #39
    Aug 2024
    Texas
    174
    how do i know when it's good? because i don't think it going to be picture perfect.?
  20. #40
    Banned
    Mar 2022
    Indiana
    4,289
    It's close enough. One thing as a final touch is to do a lot of varied driving and let the LTFT's populate. Don't have to be logging as they save on the ECU. Later you'll have to log to hit the cells and reveal them. %-half the LTFT to the VE table. Interpolate/extrapolate the trend.
