Results 1 to 8 of 8
Thread: 6L-Is there supposed to be TCC apply/release Full Throttle tables for TUTD & TUTD Hot
    Baltimore, Md
    1,394
    There is under the part throttle tables, but Full WOT ones. i know HPT has alot of missing tables here and there but I seen so many cant recall (It has tables for Normal A B Hot Engine Hot but the TUTD stuff like part throttle)
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Oct 2014
    Moscow, Russia
    272
    No, there are no TUTD WOT tables.
    There is a switch to select what should be used under WOT - Normal WOT and Hot Trans WOT or regular TUTD and TUTD Hot.
    In my 2011 truck calibration it is set to use Normal WOT and Hot Trans WOT.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Baltimore, Md
    1,394
    Quote Originally Posted by verlon View Post
    Where is that switch??
    Oct 2014
    Moscow, Russia
    272
    Quote Originally Posted by GrannySShifting View Post
    Not in HPTuners
    Baltimore, Md
    1,394
    I didnt think so. Access with EFILive or TunerCats or?
    Oct 2014
    Moscow, Russia
    272
    I doubt they have it either.
    It will be user defined parameter.
    Baltimore, Md
    1,394
    How do you access that with user defined parameters?
    Baltimore, Md
    1,394
    SO your saying it will use WOT under the Full Throttle heading or if switch is on the other way itll use TUTD ones under the Speed heading to the left? Why would there ever be a difference
    And if they are both set to the SAME, then it shouldnt matter at all right??
