Results 1 to 17 of 17
Thread: Engine Oil Hot on dash? Causes?
    Baltimore, Md
    1,454
    Calculated Oil Temp never reports hot, but I see two other values flip between -40 and numbers in the 2teens, and other 302 to numbers in the 2teens
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    2,753
    Does what you are working on have an actual oil temp sensor?
    Baltimore, Md
    1,454
    No, it does not. 2009 Pontiac G8
    Oct 2014
    Moscow, Russia
    319
    Quote Originally Posted by GrannySShifting View Post
    Your posted hpt has EOT sensor enabled. See [ECM] 312.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Australia
    2,055
    if it is a G8 then Aus based all our LS in that series had an actual oil temp sensor, the low oil level sensor in sump is a 3 wire and has a oil temp built into it
    2,753
    Do you know if the gauge is a direct read of the sensor or if the ECM still does some additional calculations to get the displayed temps? There has been a lot of discussion on the Camaro5 forum on this through the years.
    Australia
    2,055
    if it was a HSV with the triple gauges (oil press, oil temp, volts) then its reading the sensor, im pretty sure if it was the atari gauges (digital style) it is still sensor for the oil temp, there is also the setting for the sensor and mine is set to ''ecm cal and sensor'' mine is same as G8 but HSV GTS, but i know its all sensor as if i unplug it i get default min reading, and ive changed the oil when it was 100c deg i dumped it out and then refilled and checked oil temp and it was back down under the gauge start reading of 50c until the oil heated up again, as far as i can see mine dosnt follow coolant temp at all like the calculation would, i can also log oil temp sensor and oil temp cal and they do read different to each other, my gauge is same as oil temp sensor values
    Tuning Addict
    10,887
    https://www.rockauto.com/en/moreinfo.php?pk=3405651
    Weird thing is, I can't find that thing in any wiring diagrams.
    Tuning Addict
    10,887
    At sensor:
    At ECM:
    X2 23 D-GN/YE 357 Oil Temperature Sensor Signal
    X2 24 BN/RD 470 Low Reference
    X2 33 BN 1174 Oil Level Switch Signal
    Australia
    2,055
    just found this from hpt chris but copied from another forum, just explains the settings for the oil temp
    Oil Temp Config lets you set how the Oil Temp is calculated and displayed the options are:
    - Calc ECM (oil temp is calculated from ECT and a few other things)
    - Calc ECM & Disp Sens (ECM uses calulated oil temp but gauge uses sensor measurement)
    - Sens ECM (ECM uses sensor measurement if no sensor faults exist)
    - Sens ECM & Disp (ECM & gauge use sensor measurement if no faults exist)
    2,753
    Thanks. I need to see if my Camaro have these options.
    Australia
    2,055
    think its e38 ecu X2 pin 33 for the oil temp signal in
    Baltimore, Md
    1,454
    OK well the guy with the car insisted it didnt have one, checked the GM wiring supposedly and nothing for it (he was a dealer mechanic) so i guess i need to look through the thing myself LOL
    5BA8
    5,447
    I can verify those cars have a 3 wire oil level/temp sender. I just finished building one.
    email=[email protected]
    Tuning Addict
    10,887
    At sensor:
    At ECM:
    2,753
    IRC, I struggled to find anything in the wiring diagrams when I looked a few years ago for 2010 Camaro. I think I finally found it, but don't remember for sure. If I get a chance, I'll dig this weekend.
    Tuning Addict
    10,887
    It's not in the diagrams under Engine Controls, even though all the wiring only goes to the ECM. Also not in Gauges & Indicators.
