***Updated 11-15-2007 - Changed the Minimum Pulsewidth data I previously gave, and removed comments about zeroing out the short pulse adders. Also, see my post #165 within this thread for a more detailed explanation, as well as some important information!***
Here's some data we use on the Fords for the SD 60s (aka 62.7# at 43.5 psi, aka 72.39 at 58 psi):
Minimum Pulsewidth:
0.949859619140625
Injector Compensation for Battery Voltage:
Code:
VOLT PW ms
15.99 0.33886
15 0.33886
14 0.41210
13 0.48925
12 0.59082
11 0.74121
10 0.93359
8 1.44628
6 2.54101
0 2.54101
0 2.54101
0 2.54101
Use the interpolation command to fill in the values between those voltage ranges.
As an example, I took a 2000 Silverado 5.3 file and figured in the correct values for the table based on the above data. Due to minimum value requirements on the GM pcms, the values won't match up exact, but I made them as close as possible. And, no, I haven't tested this out yet, but I'm trying to get Kenny (BigKID) to do just that as I type this, LOL!
Min Injector Pulse:
Code:
RPM 0 400 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800 7200 7600 8000
Min InjPW 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745 0.95745
Offset vs. Volts vs. VAC:
This particular vehicle has a regulated system, FYI, hence the same values at all the various vacuum ranges.
Code:
0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
4.5 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826
5.0 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826
5.5 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826
6.0 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826 2.54826
6.5 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359 2.27359
7.0 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893
7.5 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746 1.61746
8.0 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961 1.44961
8.5 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228 1.31228
9.0 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020 1.19020
9.5 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287 1.05287
10.0 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080 0.93080
10.5 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925 0.83925
11.0 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769 0.74769
11.5 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140 0.67140
12.0 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510 0.59510
12.5 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407 0.53407
13.0 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829 0.48829
13.5 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251
14.0 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199 0.41199
14.5 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622 0.36622
15.0 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
15.5 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
16.0 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
16.5 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
17.0 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
17.5 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
18.0 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570 0.33570
This should be a bit of help for everyone.
