A couple of questions, guys: I recently had a TCI SSF3500 installed in my 02 Z28. I already have a tranny cooler in place. My problem is how can I get my shift points in line with the new stall. Some of the shifts are smooth but others cause the car to lurch between shifts. I've already set the DTC P0757 twice. This caused me to lose third and fourth. I cleared the code and got 3 and 4 back. If I remove this code will it prevent me from losing 3 and 4 gear? I'd rather not do this.
What parameters should I be looking at? I tried setting up a config file using the shift speed error PIDs in attempt to see how I could modify my shifts. But no luck. If someone could point me in the right direction I'm sure I can figure this out. Any help would be greatly appreciated. Thanks.
