Jime Blue Spreed sheet @ the Shift Speed vs %TPS vs Shift - Performance has all cells @ 256....mine is diffrent....Does this number mean anything.
Mine is:
Should I change it or leave it as it is
Mine is:
Holden V8 A4, Comp Cam, Headrs, ASP pullys, K&N filter, HPTuner.&&
Some of those numbers look awfully high; what is your
gear ratio? Are you displaying km/h?
I have 3.08 Gear Ratio. :-[ ues it was in KMPmy numbers are:
HOw is it now?
I recommend that for 3.08s, and speed in km/h, you take
my spreadsheet tables for 3.42s and MPH and multiply all
of the values by 1.777 - that being 3.42/3.08*1.6 kph/mph.
Then you might restore all of the values that were 255,
back to 255 (i.e. "never happen".
Be sure that the editor is properly using kph rather than
MPH when you do this, though. Otherwise you'll be 60% off.
That Hot table shown above, looks like it would never upshift
3-4 until you hit 128MPH. Not very sensible.
