I should have some GT files soon!! Today I'll be adding another GTP file.
Regarding the OBD-II LT1 files... Even the OBD-II LT1 vehicles use the 68HC11 proceessor. The flash files are also split up between 2 flash chips. I thought about this over the weekend and believe the LT1 guys will mostly fall under the OBD-I section, even the OBD-II ones.
What do you guys think?
