Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 92
Thread: Trans Segment swaps
  1. #61
    13,579
    Sweet deal bill.
    As I don't have 2.25 and havent the need for a segment swap yet but I'd assume there is a "process" to follow under this new segment swapper that you follow when it needs to be done. I guess the pictures you showed just show that it was changed under the same car.
  2. #62
    28,279
    its straight forward, load the to file, load the from file via compare, click the segment swapper button then select the segments & click copy.
  3. #63
    Dec 2008
    on the Dyno
    1,825
    NICE!!! Great work fellas. Kicking ass and taking names.
    Located in Central Kentucky
    ShorTuning
  4. #64
    Jun 2012
    10
    Sounds straight forward. I might be a dumb. I do not see a segment swapper button. The files in the compare are 2002 silverado 4l60 and 2002 silverado 4l80.
  5. #65
    Sep 2002
    Chicago, IL
    6,397
    Open the Compare menu.
    We got this guy Not Sure, ...
  6. #66
    Jun 2012
    10
    I see. So it appears I can't swap segments with the two files I have loaded (option read only)?
  7. #67
    28,279
    click open compare file & open the compare file, then click the compare window again
  8. #68
    Jun 2012
    10
    Ha HAAAA!!! you sir are the man!
    Edit: think i have the same issue. the screen shot is swapping from the same file... :/ Button shows when you're swapping segments to the same file though!
  9. #69
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    I'm assuming that having the same controller would not be sufficient, but one would need the two files to have the same VCM OD ID as well?
  10. #70
    Advanced Tuner caesar's Avatar
    May 2003
    227
    Quote Originally Posted by Pulse_GTO View Post
    Correct. You must have two files with the same operating system ID.
  11. #71
    Oct 2013
    228
    one question , when you swap the trans im assuming you also swap the diag also
    jim
  12. #72
    May 2003
    227
    Quote Originally Posted by usc45cal View Post
    jim
    Yep.
  13. #73
    Mar 2012
    If you do the trans. segment swap with the 2.25 version it´s not possible to open the file using the 2.24 anymore. What do I need to do in order to edit the file with the updated segments with the 2.24?
  14. #74
    May 2010
    Behind the wheel
    272
    Quote Originally Posted by DarkCamX3 View Post
    Save it to your machine, then flash a write entire to the VCM. Open 2.24, read the VCM with 2.24, save and edit away as normal.
    I only do that if 2.24 has a function I need that isn't ready in 2.25.
  15. #75
    Jul 2009
    Noble, OK
    317
    Just noticed this update.
    Nice work and appreciated. This will make my life much easier. Thank you!
  16. #76
    May 2003
    227
    Quote Originally Posted by gofastwclass View Post
    Flash entire is not necessary.
  17. #77
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    168
    This has been working well with Gen3 stuff. How do we go about doing this on Gen4's with seperate TCM's. Example, I have a E38 computer avalanche that originally had a T42 4l60 that was swapped to a 6l90 with a T43. I have already tuned the same swap on another vehicle with the same operating systems and want to copy just the trans tune from the original vehicle into the new one. Hope this makes sense and i am sure there is a simple work around.
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
  18. #78
    May 2010
    Behind the wheel
    272
    You can do it, just flash the TCM only.
  19. #79
    Jun 2007
    St Paul, MN
    168
    I see with the Beta you can do that. What if you do not have the vehicle present, I am trying to put together a base tune to e-mail.
  20. #80
    May 2010
    Behind the wheel
    272
    I made bench harnesses for different PCM types I typically work with and can do them without the vehicle. I typically work with P01 and P59 controllers, but I get an occasional E38 and T42.
    I love the separate flash, I've used it three or four times so far and I'm by no means a high volume guy.
