Feature request
Is there someway to modify how fast the reve limiter kicks in. I would like to be able to shorten the delay it kick in when passing the limiter threshold
HP Tuners Owner
Re: Feature request
the delay on a few bins i checked is 25ms. not sure how much it is in your bin but email it to me and i'll check, if it's a lot higher then sure we can add it.
How much is your RPM overshooting the limiter?
Re: Feature request
if set the limiter to 6700 (start executing the shift at 6500) it flashed to 6900 so 200 or so rpm after the limiter. i wanted to tighten that down because i am powershifting and if i start executing the shift at 6700 i dont want it flashing to over 7k definately not on the stock bottom end.
Mail sent
