Results 1 to 7 of 7
Thread: 2010 camaro, stumble after 2500rpm shift
    I've got a car I've been working on this afternoon and the only thing that I can cure is a slight stumble at low throttle position after shifting around 2500. Shifting at 2500 drops RPMs back to 1500 and it will stumble for a split second and than clean up. MAF has been tuned, A/F is 14.5-14.7 cruising without any O2 input and 12.6-7 at peak torque and 12.9 at peak hp.
    Phil
    1999 Corvette Coupe
    Worlds Fastest 346" N/A Coupe
    ProStreet Motorsports
    HP Tuner SD specialist All GM Vehicles
    2000 Mustang 438" LSx 4.70 @ 164
    NEW 346" N/A testing: 10.4 @ 132.4 N/A(875')
    NHRA Corrected: 10.21 @ 134 N/A
    Old Nitrous Best: 10.0 @ 138.89(181 DA)
    What type of induction? If fabricated how stable is the maf output?
    I've only seen what you describe occur on fabbed intakes where the maf sensor is located too close to a bend radius. Other than that I would log torque management.
    07 ZO6- warhawk 427/APS TT/HPT 2.5bar
    [email protected]
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Sounds like MAF error to me.
    618/618 motor
    906/862 spray
    Quote Originally Posted by INTMD8 View Post
    Its got the filter off to the driver side with a straight pipe runs behind the radiator turns 90 degrees into the throttlebody. The straight pipe is maybe 12-18" long and turns right into the TB. The MAF is almost at the end of the straight section before the turn. I dont think that is the problem.
    Phil
    1999 Corvette Coupe
    Quote Originally Posted by IDRIVEAG8GT View Post
    I am going to retune it on a load cell dyno and spot check the A/F on sunday.
    Phil
    1999 Corvette Coupe
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    can u post up a file... if you've tuned the maf only, it might be the transition from a certain set of Hz on the Maf table that have had too much fuel added to them...
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Aug 2006
    5BA8
    3,493
    Quote Originally Posted by Phil99vette View Post
    Can you relocate the MAF to the other end of the straight piece of pipe? In other words, get it away from the bend.
    EFI specialist
    email=[email protected]
