Results 1 to 5 of 5
Thread: Scanner Plus? What is it?
    Jan 2004
    Toronto, Canada
    21
    On the products page at the bottom under Upgrades it says:
    VCM Scanner Plus
    The VCM Scanner Plus contains all the basic features you will find in the regular version of VCM Scanner plus the following support:
    Perform Case Learn Procedure
    Turn Fans On and Off
    Reset Fuel Trims
    Command Open and Closed Loop Operation
    I'm confused. Is this an add-on package or a recent software update. I can't find any other info referencing it.
    \'98 Grand Prix GTP&&[email protected]&&(bottle fed)
    Jan 2004
    Kitchener, Ontario, Canada
    19
    Re: Scanner Plus? What is it?
    can you move the abs modulator piston with the scanner plus?
    --matt
    Sep 2002
    Chicago, IL
    6,397
    The scanner plus is just an upgraded version of the regular scanner which allows you to do PCM Control functions... turn on fans, command trans gear, case learns, etc. etc.. The plus will not be available for about a month or so. Its a $99 upgrade. We will be adding many features to the plus to make it worth the $99 upgrade cost.
    We got this guy Not Sure, ...
    Can i force a blm to the PCM?? can I put a number for her to learn so changes doesn't take that long??
    Or if I can "back up" my BLMs, reflash and then put them back and watch the changes?
    Sep 2002
    Chicago, IL
    6,397
    We are working with the BLM learns as well. This will happen in a future release.
