Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: LNF Guides
    Dec 2008
    Nevada
    4,450
    Post LNF Bible
    Hoping this will become a sticky for LNF since we have so many great threads that have fallen to the dark and we keep seeing questions about them all the time.... im on the forum alot so as new developements arise i have no problem adding the information to this first post keeping this up to date.
    ***Information can be interpreted different ways between readers so as usual ask questions in the appropriate thread to clear any confusion and calibrate at your own risk!
    LNF Histogram Custom PIDs:
    HPT3.XX Histograms LNF/LHU/A20NFT/A20NHT/Z20NHH
    DI Ecotec Histos.Graphs.xml
    LNF Custom .pids (CDNIGHT reorganized)
    http://www.hptuners.com/forum/showthread.php?t=38361
    LNF Tuning Guide Video (Old Software Version)
    http://www.hptuners.com/forum/showthread.php?t=38868
    everyone's finds wrapped up in a narrated/visual follow along at own pace kind of deal
    Generic Starter File
    http://www.hptuners.com/forum/showth...-Starter-Flash
    Fueling and Calibration threads:
    Nick's LNF Tuning Guide
    http://www.hptuners.com/forum/showthread.php?t=26232
    Maf tuning (BYT)
    http://www.hptuners.com/forum/showthread.php?t=26756
    maf calibration with pics(BYT's info explained simple as possible by CSSOB)
    http://www.hptuners.com/forum/showthread.php?t=35129
    Kr Sensor Adjustment to Filter some False Kr
    http://www.hptuners.com/forum/showthread.php?t=30115
    Ethanol Fuel Blend Threads:
    Ethanol Blend Calculator
    http://www.intercepteft.com/calc.html
    this tool can be used to help calculate the current value of ethanol you are running when mixing pump gases with E85 (the lowest chart tends to help the most)
    Tom's (Iambroke) E85 thread
    http://www.hptuners.com/forum/showth...e85+experiment
    BYT's first stab at E-tunes
    http://www.hptuners.com/forum/showthread.php?t=34324
    This thread, is a good 'read', as it shows how hard Nick, worked, to develop a good running Ethanol tune.
    more BYT findings
    http://www.hptuners.com/forum/showthread.php?t=35111
    Torque Management threads to include Turbocharger Settings:
    Basic LNF/Bosch ECM torque based engine management info
    http://www.hptuners.com/forum/showthread.php?t=20339
    Torque Management Injector Disable table and it effecting DFCO
    http://www.hptuners.com/forum/showthread.php?t=28714
    Turbocharger wastegate controls
    http://www.hptuners.com/forum/showthread.php?t=33467
    Torque Management kills DEFCO(GMtech)
    LNF Turbocharger PID Tables
    http://www.hptuners.com/forum/showth...LNF-PID-Tables
    Camshaft Phasing Threads:
    Basic VVT Info
    http://www.hptuners.com/forum/showthread.php?t=35092
    Lots of good info on Cat Warmup Delete and Cam Timing
    http://www.hptuners.com/forum/showthread.php?t=33878
    Cam Phasing Talk as of March 2012(GMtech/IAMBROKE/CDNIGHT/Stromboli/CSSOB)
    http://www.hptuners.com/forum/showthread.php?t=38308
    Cam Timing Help
    http://www.hptuners.com/forum/showthread.php?t=22247
    Bringing it back LNF Injector Timing
    http://www.hptuners.com/forum/showth...jection+window
    LNF Cam and Injector Comparison
    http://www.hptuners.com/forum/showth...n-to-Cam-Table
    Idle and cold start:
    Idle Timing Cold Starts
    http://www.hptuners.com/forum/showthread.php?t=36029
    More issues, Dayhoff's idle problem
    http://www.hptuners.com/forum/showthread.php?t=35943
    GMPP Kit Information:
    More good info from Tom (Iambroke) about 3bar maps
    http://www.hptuners.com/forum/showthread.php?t=35860
    Advanced Tuning Threads:
    Codename Bil Doe's LNF Tune (Road Race and Street Use) With Explanations
    https://www.hptuners.com/forum/showt...nd-explanation
    Optimum Spark Tables / Torque Management (Read and Adjust at Own Risk!) GMTech
    http://www.hptuners.com/forum/showthread.php?t=39660
    **These tables are powerful and important to the lnf. If you get carried away on these tables, the side effects can be odd or flat out unsafe. Adjust these at your own risk. It is highly recommended by many community members to have an high level of understanding in regards to table effects within the ecu. It is most often the case that one table is not just making a single change, but it is also effecting 2 to 3 other tables as well. It will be easier to understand the Opti Spark/Torque tables after practicing and learning the table interlinking effects with the more basic tables.
    Optimum Spark How-To (Read and Adjust at Own Risk!) Codename Bill Doe
    http://www.hptuners.com/forum/showth...-tables-how-to
    **See same warning from above.
    Aftermarket Turbocharger Tips and Problems/Corrections:
    LNF ZFR Turbo Midrange Injector Spark Blowout Issue (Terminator2)
    http://www.hptuners.com/forum/showth...e-this-One-Out
    New Table Releases:
    Current beta table releases (Bill@HPT)
    http://www.hptuners.com/forum/showthread.php?t=33449
    cat delete/turbocharger settings/fuel pressure modification/fuel window modification/fuel injector calibration tables/extended torque control tables
    lots of goodness in this thread from a nice array of master tuners.
    The First Share Thread (GMtech)
    http://www.hptuners.com/forum/showthread.php?t=33473
    LNF Engine Swap Stand Alone Info
    http://www.hptuners.com/forum/showthread.php?t=36755
    Documentation:
    MIT Knock Testing on Direct Injection
    https://docs.google.com/file/d/0Bwxy...it?usp=sharing
    MIT Ethanol Testing on Direct Injection
    Ethanol Fuel Blends in a GDI VVA Flex Fuel Engine
    http://delphi.com/pdf/techpapers/2011-01-0900.pdf
    Direct Injection Ecotec Comparison Thread
    http://www.hptuners.com/forum/showth...DK-LHU-Compare
    Common Map Sensor and Calibration Data
    http://www.hptuners.com/forum/showth...l=1#post400484
    Inspection/Maintenance System Force Test
    http://www.hptuners.com/forum/showth...562#post454562
    Last edited by cobaltssoverbooster; 04-21-2021 at 08:06 PM. Reason: highlight url links
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Wow.... Just wow.
    Some of the links above need to be fixed. If they contain ... they don't work. Good job though.
    Dec 2008
    Nevada
    4,450
    haha ur definately old.....
    i tell you what though i will color the links just for you 8D
    ohnsetly its nice to have all the info in one accesible spot....also its not crowded with config files....although if we had a thread for lnf config files or custom histograms repository thread for lnf where everyone could see how we look at cams, ignition, fuel, and all that goodness. it would be a nice add to the list of threads.
    Jul 2009
    2,305
    Try the 'Ethanol Fuel Blends Thread' link above before you call me old. Iz invented the interwebz before you waz borned, young'un. Back then we used BBS & 300 baud modems.
    None of them link directly in Chrome, can't even paste that one in with the dots in it.
    Dec 2008
    Nevada
    4,450
    wow i definatley did something wrong lol.
    maybe im old...
    alright urls are linked test them out
    Links works for me in Chrome.
    Thanks for putting this together, and also thanks for everyone's helpful replies!!
    I've got some more threads starting soon on other tables, please share on those too.
    Dec 2008
    Nevada
    4,450
    yep ill track them
    Jul 2009
    2,305
    This one's still broken.
    Ethanol fuel Blend Threads:
    Like I said, the ... in the link kills it.
    Dec 2008
    Nevada
    4,450
    i seenow
    Dec 2008
    Nevada
    4,450
    ok bugs out now?
    Jul 2009
    2,305
    Works now here.
    This is amazing!!! I want to thank all of you for the past week I was doing research and bookmarking all I could find on the LNF to do reading. Just purchased a Sky RL a month ago and got my HPTUNERS in.
    You guys saved me so much time Big Thanks!!!
    Dec 2008
    Nevada
    4,450
    updated
    added ethanol belnd calculator
    use the link and the lowest chart on the website tends to help the most.
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    Ive got two major break throughs I discovered today. Il have you add them after I get some time for a write up.
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
    Jul 2012
    Columbus, OH
    81
    This is probably going to be my bible for the next few months. lol Great post!
    Sep 2011
    17
    Now something like this for the LSJ!
    Dec 2008
    Nevada
    4,450
    Updated this today....
    Im still watching the LNF VE thread grow to make sure its a proven calibration technique for the lnf.
    also if anyone wishes to help with the videos for the LSJ Platform i have some time again and wouldnt mind giving all the credit to someone who can help me hunt down lsj threads and refresh my memory for tuning them to help this go faster and be more accurate. i openly admit its not my strongest platform so help on this will bring a better end result.
    Feb 2012
    4
    Awesome, thanks for the info.
    Amazing thread! Subscribed
    Dec 2008
    Nevada
    4,450
    *update: add Aftermarket Turbo Section
    Request: If anyone with a Aftermarket Turbo wishes to help the community we could use a thread to help with what to expect when tuning for different turbo swaps and if you ran into a rare problem what happened and if possible what was causing it.
    Turbo Chargers Currently used: S20G-ET / BW EFR (ZFR) / S256-ET Bullseye Power/ Garrett GT/GTX series from 2876r-35r
    if you happen to have a holset or turbonetics we'd love to hear about those too!
