My 2000 SS is throwing a PO 300 Misfire code after I replaced the Alternator and belt. ??????? Coincidence???? Voltage is good.
I have replaced the plug wires, as it was my next project. Still same problem. Going to get new plugs and fuel filter later.
HP Scanner is showing Cylinder 7 with misfire history, 2000 or so and cylinder 2 a couple of hundred.
In reading my GM shop manual, one of the tests called for is :
Force the fuel system into Open Loop.
Is that the VCM controls Fuel and Spark tab? That has the Closed Loop On and Off control.?
If so, is turning closed loop off accomplish this test?
Any additional help would be appreciated.
Have fun..............Im not.
