Can anyone help I am after standard bin files for the Holden 300KW map based program (DSKW mask) both Manual and Automatic transmission types
Hi, If you can get me some example vin numbers i can pull a couple out of sps for you. Then just post them on the bin repository.
fast as fast can be..... When i hit the nos, youll be sayin... WAIT4ME!!!!!
Thanks Wait4me, unfortunately I do not have any VIN numbers.
I think a lot of us would find this pretty educational, I hope
you can turn something up.
i do have a mafless gts 2001, Is that one that will work?
i went ahead on put it on the site.
;D was hoping someone would post one of these bin filesOriginally Posted by wait4me
Excellent ...
This is just what i need as a base too
Does anyone have an idea how much i need to scale things back from this to an LS1 manifold/injectors, being that this would be LS6.
Then , ive got an excellent base to start from...
for uploading it !
wait4me, when you say pull file from sps! are you able just directly access the file or do you have to go through a programming sequence? I would be tickled pink if someone could explain to me how to pull files off the sps system!
There is no replacement for displacement?&&sure there is, its called a Blower!
i cant tell i was shown the light.... everything is in a file called rfile.000 the database you can log into it as badmin and select not to insert a password. then it will let you into the database and you can even see all the vcn configuration codes and what they mean.
ok, i found the file but now what do i use to view it? SQL? Oracle? Access?
anyone been able to get sps working outside of holden dealership?
