Results 1 to 9 of 9
Thread: Mode 2 Write Error?
    Baltimore, Md
    1,213
    Mode 2 Write Error?
    Not sure what this means, but tried to reflash a Camaro calibration to an 00 Silverado PCM both had the same hardware number so not sure why it wouldnt work. Kept popping up that error New Bitmap Image.jpg
    Could even reflash the program I pulled out of it back into it?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Dec 2009
    1,084
    IIRC This is because you are trying to flash a Different OSID and Vin which wont work.
    I don't believe it would even work with a "write entire"
    Baltimore, Md
    1,213
    Same OS ID. I have all the Gen3 stuff, Ive flashed same hardware with Corvette or Fbody file etc. And that doesnt explain not being able to flash it with its OWN file I pulled from it?
    Dec 2009
    1,084
    Quote Originally Posted by GrannySShifting View Post
    You posted you COULD
    Dec 2009
    1,084
    And the F body Osid is different than the Sierra Osid according to your screen capture.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Hook up jumper cables.
    http://www.dsxtuning.com
    Just say no to bull s***.
    28,287
    this error usually indicates a battery or wiring issue.
    has 0 to do with the os id.
    Baltimore, Md
    1,213
    OK thats even wierder then. Original file was written in the chassis, car was started everything worked as normal. The shop had another spare ECM they wanted me to flash the same stuff to as a backup spare, bolted it in and get this. Put the original in it, flashes fine starts fine?
    Baltimore, Md
    1,213
    Quote Originally Posted by planethax View Post
    didnt catch the nt typing fast I guess, doesnt read right if I could even that dont make sense LOL
    OS on that screen capture is different because I was trying to write 3bar OS onto it. I later tried flashing the stock file that was in comp A into comp B (both end is 1344 OS or something) and that didnt work
