Greetings,
I just installed a LC-1 connected to USB HPTuners EIO and it worked great for a couple of days but now it just reads 7.4 constantly and I have done a free air calibration. I did the free air by removing the O2 sensor and then tried turning power on and after it had warmed up press the button. This didn't make a difference so we disconnected the LC-1 module from the sensor with the power off and then turned the key on for 30 seconds and then turned it off. We then connected the sensor and powered it on again for 2 minutes, it did the correct LED sequence I think(slow flash, fast flash, off, and then on). Then turned it off again and connected the USB EIO and started up HPtuners, still the same issue so I connected the serial cable to the other output of the LC-1 and it shows 14.6. Any idea's? I have double checked the EIO input on hptuners and have it set to AUX LC-1. I also connected the 2nd analog output(yellow) to the EIO and its output is the same. I haven't modified anything on the LC-1 with the programmer and I am puzzled why this worked just fine a couple of days before?
Thanks for any help!!
