Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
Thread: Help me run a flex fuel setup on a C5Z06 n/a 427
    I think I need a P59 ECU, but is this even possible? I'm getting a lot of mixed answers. Any insight would be greatly appreciated.
    77 C10 - 416 6L90e Swap
    Its been done....
    But there are no files you can get from the manufacturer... most files will not crank or will not start the car.
    Sep 2008
    1,668
    The only P01 OS that I know of that can support flex fuel is from a 2002 SUV, 12216125, but as mentioned above, I don't know if this OS will start the car or have everything else in it work properly.
    The 2004 C5 had a P59, flex fuel tables are present there, but it's not enabled...that's probably your best bet to enable it, but I believe we're still missing some of the necessary tables to get the PCM to add spark properly when the alcohol sensor see's alcohol in the fuel...if you can write entire with another vehicle file that was factory flex fuel, this isn't a problem, but it still would take you away from a C5 file and go to a truck file...may still work, I'm not sure.
    2023 Durango Hellcat
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by MikeOD View Post
    The p59 controller is the answer. There is at least 1 fully functional flex OS's for it, and it has boosted support. There are also 4l80e deferments for the same OS. Also cable and dbw support depending on the ecm itself.
    I'm currently trying to track down wiring diagrams to see if I can get one to run the gauges in a 4th gen fbody.
    Sep 2008
    1,668
    I''m guessing you mean the 2005 OS, 12592618...came in the Avalanche with flex fuel and 2500HD with the 4L80E.
    The gauges should just need to connect the serial data line.
    Aug 2012
    SV, AZ
    447
    Yes sir.
    Baltimore, Md
    1,211
    So did anyone get anything done with this?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Aug 2012
    SV, AZ
    447
    I should be done with a 4th gen fbody by March. Just waiting on the last few things to show up for install.
    Anybody get around to making this work in a c5 and retain the DBW? Im about to swap a p59 pcm into mine soon to try to make flex fuel work but honestly i have no idea what im really doing haha
    1999 corvette FRC - LS2, Tick tq max stage 3 cam, AI 232cc 243's, FAST 102 intake, NW 102 TB, 1 7/8 headers, X pipe, Borla ATAK, McLeod Rxt, MGW shifter, Halltech Killer Bee intake, 4.10s
    Yes. Super easy. It even measures fuel temperature out of the sensor
    Jul 2016
    250
    Did you just swap to a p59? The guys on corvette forum make it seem like it's more than that.
    Quote Originally Posted by hodge9386 View Post
    Yes I've done it and retained the DBW throttle body. If I remember I used a SUV OS, did a segment swap and since the suv OS only has one output for fan control I wired second fan with a relay to the one output.
    Jul 2016
    250
    Quote Originally Posted by Kaganader View Post
    Do you know what OS the p59 vette uses? I have a 05 Avalanche file that is OS 12592618 that is flex fuel and 2 fans.
    Nevermind, Vette OS is 12587603
    Jul 2016
    250
    04 Tahoe with flex fuel is OS 12587603 . It has the option for 2 fans that should work with the stock c5 fans.
    is the suv os compatible with the factory c5 tac module and throttle body? i know in the trucks you have to use a x link to use a ls2 throttle body
    Jul 2016
    250
    I think you can just use the segment swap for the fuel side to use the flex but some people have said that there are hidden parameters that wont let that work and results in a no start in the c5.
    I have not tried the swapping the full OS. I have an 01 so I would have to do a rewire for the p59 then try the two above.
    Autowiz cover how to use the silverblade with the gm trucks in this thread
    https://www.hptuners.com/forum/showt...2005-silverado
    I have a p59 out of a 04 tahoe. I plugged it in the car today and read the file and it is already a flex fuel enabled pcm. What else are you saying i need to segment swap to make it work? I havnt had a chance to make the changes from my c5 pcm over to the p59 and load it to see if it will start. I will try to get to that tomorrow after work.
    I see that a 2004 z06 uses the same OS so would it be better to segment swap all the 04 z06 segments over to my 04 tahoe pcm except the fuel segment? Now that i look at the segments the only segment IDs that are different are the fuel segments.
    I also have a question about the platform type and system options. Should i leave that GMT800 or change it to GMT530 like the original c5 pcm or Y like the 04 z06?
    Jul 2016
    250
    I would try swapping the fuel segment to the z06 0S first and if that doesnt work try using the Tahoe OS.
