Results 1 to 13 of 13
Thread: 2015 denali no start after flash
    Tuner 69camaro5speedefi's Avatar
    Dec 2005
    INDIANA
    57
    After a flash engine will not crank or try to crank
    I put a tune that has been running back in, still no start unhooked battery couple times nothing
    fuel pump comes on, it like the start is not told to crank any one seen this ?
    28,279
    email support please.
    Mar 2014
    McAllen,TX
    160
    This has happened to me also remove baterry for 5 minutes connect it and full write up
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Dec 2005
    INDIANA
    57
    With all the bells and whistles coming on and me trying to figure out the problem it has managed to lock the doors after that battery got to low lol Now I sit with a $115,000.00 denali 427 whipple with the customer on a boat in costa rica that can't be reached
    why gm did not put 2 batteries in this thing I can not figure out more lights,screens,running boards ect coming on what a mess
    Dec 2005
    INDIANA
    57
    Quote Originally Posted by Joshtuning View Post
    did not work for me
    Mar 2006
    25
    GM does recommend having a supplemental charging device while flashing for future reference. But yes, it sucks.
    Apr 2006
    42
    Spend the $400 for a programming power supply from Midtronics. Stable 13.5V with current supply up to 70A, keeps even a dead battery nice and stable when doing long programming events.
    Also, roll the windows down. Never trust the key-less entry system.
    Nov 2005
    southeastern indiana
    15
    Quote Originally Posted by ecotec88fiero View Post
    Nov 2005
    15
    [QUOTE=69camaro5speed;412126][/QUO
    I did 14 with out battery going dead it got low after it wouldn't start to charge it and I made a Temp to reflash it couple times ,I normally never leave the key in of course the one time I do, so some one can drive while I push it inside the doors lock,
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    The Schumacher inc-700a is a great power supply for keeping voltage stable during flashing. Very common in the BMW world and will work just fine on GM's too.
    Dec 2005
    INDIANA
    57
    Problem fixed,after 14 flashes 50 miles of driving ,many start ups ,checking fluids, starter wire gets loose after I back it out of my house garage 15 ft for some idle tuning and do another flash bam no start, another flash fails trans side for first time so me thinking ok look for codes guess what no trans communication code
    damm this is right up there with the 95 lt1 with a brand new (name brand) fuel pump that dies after a flash or the lifted duramax with the wheel sensor wire that shorts out making it flip out,on and on
    I was thinking about checking it sooner but my tools where at my other shop
    sorry hpt for the e-mails wasting your time
    now on to tuning and on the dyno
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Was it loose from the factory or did you have it off for some reason?
    Dec 2005
    INDIANA
    57
    It was off for the 427 install yes ,it had many start ups and 4 test drives
    after looking at it I can see how it was not 100% locked in very tight fit with headers
