Results 1 to 11 of 11
Thread: E40 Benchtop Programming
    Tuner Ricardo's Avatar
    Jul 2011
    5000 ft ASL
    79
    Anybody have a link or diagram for a DIY E40 Benchtop harness?
    Ricardo
    1996 A4 FBody with LS7 swap
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Will this work
    Jul 2011
    5000 ft ASL
    79
    Thanks I will look into building one.
    Ricardo
    Baltimore, Md
    1,213
    Looking to modify my current LS1 PCM harness to be able to do E40 and the TCM as well.
    Anyone know best source to get blue ECU connector and the TCM connector?
    Also what pins the TCM needs to comm?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Aug 2008
    Chicago
    98
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Aug 2008
    Chicago
    98
    Connector Part Information
    •15463921
    •Conn 49 F Micro-64 GT 280 (BK) Sealed
    Pin
    Wire Color
    Circuit No.
    Function
    BN
    418
    TCC PWM Solenoid Valve Control
    L-GN
    1222
    1–2 Shift Solenoid Valve Control
    3–4
    Not Used
    5
    BU
    381
    Vehicle Speed Signal
    6
    BN
    2501
    High Speed GMLAN Serial Data Bus − (CAN)
    7
    BN/BK
    2500
    High Speed GMLAN Serial Data Bus + (CAN)
    8–10
    Not Used
    11
    BN/WH
    1843
    Accessory Voltage
    12–13
    Not Used
    14
    WH
    898
    Shift Solenoid Valve 3 High Control
    15
    Not Used
    16
    PU
    401
    VSS Low Signal
    17
    OG/BK
    1228
    PC Solenoid Valve High Control
    18–19
    Not Used
    20
    YE/BK
    1223
    2–3 Shift Solenoid Valve Control
    21–22
    Not Used
    23
    GY
    773
    Transmission Range Switch Signal C
    24
    PK
    1224
    Transmission Fluid Pressure Switch Signal A
    25
    BN/BK
    422
    TCC Solenoid Valve Control
    26–28
    Not Used
    29
    BN/RD
    771
    Transmission Range Switch Signal A
    30
    YE/BK
    1227
    TFT Sensor Signal
    31
    PK/BU
    339
    Ignition 1 Voltage
    32
    OG
    740
    Battery Positive Voltage
    33
    OG
    1226
    Transmission Fluid Pressure Switch Signal C
    34
    Not Used
    35
    BK
    2762
    Low Reference
    Aug 2008
    Chicago
    98
    Schematic is from a 2006 Gto
    Baltimore, Md
    1,213
    So I would need CAN # 6,7 tied into the CAN wires at OBD port
    #11 accessory voltage?
    Def #31 Ignition voltage, 32 battery voltage
    And #35 low reference should be ground right?
    Aug 2008
    Chicago
    98
    Quote Originally Posted by GrannySShifting View Post
    Correct, pins 6 and 7 tied to the CAN wires at the OBD port.
    Pin 31 is ignition 1 voltage
    Pin 32 is battery positive voltage from ECM
    Pin 35 is low reference
    Attachment 80557Attachment 80558
    Baltimore, Md
    1,213
    Quote Originally Posted by 01SLPSSM6 View Post
    Your attachments didnnt work
    Aug 2008
    Chicago
    98
