Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: 2003 Chevrolet Express van with Lq4 - tuning for T56
    Tuner Hotwire's Avatar
    Jun 2013
    Greensboro, NC
    115
    Thanks guys, engine is stock except for cam (220/224 112 lsa .575"lift), Pac 1218 springs, too big long tube headers, t56, and 3.73 gears. I've got svo green top injectors to install but was going to wait until I had the base tune figured out.
    The tac module is hopefully the right one? Don't know how to identify it but has numbers etched into the module, nothing on the pedal.
    Box=12573059
    TMD1-160A1
    209-024894
    *Jeff*
    2002 4dr 2wd Blazer, 06 L33, LS6 cam, built trans, etc.. SOLD
    2008 Tahoe Hybrid 2wd, 6.0L LFA (stock dd)
    1964 Chevelle Malibu 4 door, 2003 LQ4, 06 GTO T56 swap -> https://www.chevelles.com/threads/19...-build.955866/
    Jul 2005
    arkansas
    530
    I am doing a very similar thing. Nv4500 with a 2003 dbw Tahoe computer and tac. I do have a stock tune and couldn?t get a 2004 Silverado to Work. So I?m not sure what to do. I can?t find a 2003 manual tune any where
    13,588
    Am I safe to assume you got the harness, pedal and throttle body from a 2003ish silverado and picked up the computer separately from another guy?
    I don't know the best course here but writing in a file that matches the harness you have wouldn't be a bad idea. Not having the ability to use the segment swap isn't a huge problem. You can still disable all abuse and transmission related settings and have the engine work just fine.
    Jun 2013
    Greensboro, NC
    115
    I purchased the complete setup from 1 individual. He'd purchased it as a spare for his turbo truck but sold the truck. Unsure of how I ended up with this certain ecm setup. I was told everything was out of a 03 express but this harness has 4wd connections?
    Just found an 03 Silverado manual on Craigslist 1.5 hrs away. Guy told me he'd allow me to hook my computer up! Stay tuned!
    *Jeff*
    Jul 2005
    arkansas
    530
    It would be fantastic if you didn?t mind posting that file.
  6. #26
    Jun 2013
    Greensboro, NC
    115
    Meeting up with him Saturday, I'll put the tune in the repository once I get back and have connection.
    Hopefully this will help solve the problem, if not, I may have to lean on you guys a little to help me stumble through this. I've tuned cars before but this is my first complete screwup from the start with segment swapping and everything else needed..
    *Jeff*
  7. #27
    Jul 2005
    arkansas
    530
    Do you know if his is dbw? If all else fails you could just do a full rewrite if his file has every thing yours does. It would cost credits but it would easily fix your issue.
  8. #28
    Jun 2013
    Greensboro, NC
    115
    I'm pretty sure it is. Guy's gone radio silent, so I've started looking down different avenues. Found some 6.0/manual trucks on Craigslist that have posted VIN. Going to contact old friends to see if I can get it flashed inexpensively. Either way I'll share what I go with.
    *Jeff*
  9. #29
    Jul 2005
    arkansas
    530
    I?ve ran my 04 Tahoe computer on his 03 tac and pedal before. I was able to get my file to accept the segment swap. Both p59 iirc so I?m going to try that. Only issue with my computer is it made his Colorado fuel gauge read backwards. But I changed the information from his file for that to mine. Going to try a full write and see what happens.
  10. #30
    Stock '03 Sierra 4.8/NV3500 Tune
    Just saw this thread hoping for help in cleaning up some misfire codes on my '03 Sierra 5-speed. Hope this helps the OP.
    '18 Sierra L5P
    '03 Sierra 4.8/NV 3500: LS6 Cam, HPT Tuned
    '15 Explorer Sport - SCT, AEM (Wife says...it feels faster??)
    '01 Z06
  11. #31
    Jun 2013
    Greensboro, NC
    115
    Quote Originally Posted by Closer_2001 View Post
    Thank you very much for sharing! That would have definitely solved my problems, just opened it up, was able to segment swap everything.
    I went to the pull a part this morning, cold as hell, but 40% off, got an 05 suburban ecm for $28. Swapped in CTSV segments, I'm good to go, except for stuck injectors.
    Thanks again Closer_2001!
    *Jeff*
  12. #32
    Jul 2005
    arkansas
    530
    I wound up segment swapping my 04? Tahoe file and doin a full write to the 03 Tahoe computer. Only thing that seems off is it will start with clutch out. I think the switch needs adjusting.
  13. #33
    Feb 2018
    Sorry to bring up an old thread, but I can't see the attached file from you Closer_2001... It would be a great help if you could try posting it again? I need to segment swap for a manual transmission as well so I can use my reverse lockout... Thank you!
  14. #34
    Jun 2013
    Greensboro, NC
    115
    Quote Originally Posted by cfish60 View Post
    I can't share files through mobile but if you go to this thread you can grab my tune:
    https://forum.hptuners.com/showthrea...iles-histogram
    *Jeff*
  15. #35
    Feb 2020
    I know Zombie Thread!!!
    Could you post a picture of where the shifter for the T56 end up in the VAN??
  16. #36
    Jun 2013
    Greensboro, NC
    115
    Quote Originally Posted by haphazard6 View Post
    Sorry but this combo is in a 64 Chevelle.
    *Jeff*
