Results 1 to 16 of 16
Thread: 2018 Cruze 1.4 Stock read
    anyone have a stock read for a 2018 chevy cruze 1.4 turbo? thanks.
    Apr 2011
    Chicago, IL
    763
    Here is my 2017 le2 premier stock file - not a 18 i know but the repository doesn't have a 2018 but figured id post it up for you anyhow
    Attachment 88503
    thanks
    Jan 2019
    7
    Is that car flex fuel compatible? It looks like the sensor is enabled.
    yeah it is, my wifes 2017 premier has the sensor from factory. pretty neat
    Jan 2019
    7
    Wow, I bet those little cars could be pretty fun with a little tune running on E!
    been wanting to mess with it but knowing how notorious these things are about breaking pistons, i'm just going to leave it stock. Lol
    Apr 2011
    Chicago, IL
    763
    Yes they do. P0300 - low compression cylinder one usually. If you catch it in time you may avoid cylinder wall damage. however you get a few curveballs here and there with a cyl 2,3 and 4 for time to time
    So glad I found this thread. Thanks for posting the tune. I'm going to have to check it out when I'm at a computer. I put a Cruze turbo on my chevy spark and installed a flex fuel sensor. Some of the tables in this tune should be helpful for me. Thanks again!
    Apr 2019
    4
    I will soon be plugging into my 2018 Cruze for the first time to copy the stock file.
    Any tips?
    Maybe I will look for the flex fuel sensor as well. Would be nice to play with it though I have not seen them advertised to be flex fuel. A lot has been posted on the LSPI problem. The 2016.5 should have different programming than older ones with the 2018/19 being solved for the most part.
    Tnx
    G
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    Quote Originally Posted by gmansyz View Post
    Any tips?
    Tnx
    G
    When you download the stock tune of your 2018 Cruze, in the tune under Fuel / Flex Fuel / there is a enable/disable option. If your car has a flexfuel sensor, then that option in the tune will read "Enabled". If it says "Disabled", that means you don't have a flex fuel sensor.
    If the stock tune doesn't have that FlexFuel Option, that means your engine doesn't have the proper fuel system to support flexfuel,... ie bigger injectors and whatnot.
    Mar 2019
    18
    I have a 2018 cruze. Factory enabled flex fuel and according to flow rate on injectors it has 76 lb/hr. Logging the car the alcohol % stays at 9.8% put 2 gallons E85 just to see what would happen and my ltft are up 25-27% the alcohol % hasnt moved and still says stoich is at 14.12. How do I know if it has a flex fuel sensor or if everything is working properly?
    Baltimore, Md
    1,211
    Quote Originally Posted by oleblue07 View Post
    Change the Delay Volume and Transition Volume to 0 - sometimes takes long time for it to realize change in content with stock settings
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    care to share your stock read? thnks
    Mar 2019
    18
    2018 cruze STOCK.hpt
    Here is my stock read. also after 20 mins of driving when my fue trims were up 20% my check engine light came on
    Oct 2019
    Brazil
    13
    1.4T 2019 flexfuel (brasil) original read
    Chev Cruze 1.4T 2019 ORIGINAL.hpt
