Results 1 to 15 of 15
Thread: Startup issue, commanding 0 desired idle rpm?
    Baltimore, Md
    1,211
    If I set it to 1000rpm with scanner controls it all works normally but left to its own devices it tries to make it idle at 0 rpm even though thats not whats in the tables.
    I think I remember someone having issue with a Max Idle RPM table set to 0 but that was in manual OS I think, this is a 4L80e segment swap, with the PN Only switch set to indicate when in/out of gear.
    Pull it into gear and pretty sure desired idle goes to normal because it will usually calm down
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Baltimore, Md
    1,211
    Figured this out, with workaround. So if you put shifter in gear for a couple seconds, desired Idle rpm creeps up to normal, then you can put back in park and it start with correct targeted idle. Something in the background of this OS has Max Idle in P/N set to 0 rpm somehow not sure being an auto 80e OS. Maybe can see it in EFILive
    Set up park/nuetral indication different and works normally. Go figure
    Sep 2017
    736
    Quote Originally Posted by GrannySShifting View Post
    Had this same same issie with my 24x swap lt1 as did a few others i know. Havent had the issue in a while. Never figured it out.
    Sep 2017
    736
    Actually just fired mine up today. It does the same thing.
    Will command 0 and want to die but if i put in D the park its fine.
    Other than that runs great
    Wonder if i start in N if it will do it?
    Jul 2015
    925
    Is this a swap. If so you need to change the PRNDL PID. I've ran into the same thing.
    Sep 2017
    736
    Quote Originally Posted by Jay@HAP View Post
    Its an lt1 with 24x ls1 pcm and 4l80e. What PRNDL PID?
    I did notice when im in park it reads gear 1
    Sep 2017
    736
    My PRNDL in system settings say none. Should i move it to PRNDL? not sure how it works with an 80e?
    Jul 2015
    925
    Try PN only. I went back and looked on the last swap vehicle I did. It was a LS1 w/ 4l60 in it.
    Sep 2017
    736
    Ok i will. Compared to a stock fbody file and they all say none
    Baltimore, Md
    1,211
    If you notice in my file, it IS set to PN only
    Tuner in Training BADWOLF's Avatar
    May 2019
    Maine USA
    15
    Looks like the original tune was a manual, made some adjustments..you may have to tweek the BRAF P/N
    Edit; The idle max P/N and BRAF alone might get it for you if the other parameters have been changed to suite your setup...
    Sep 2017
    736
    Quote Originally Posted by BADWOLF View Post
    BADWOLF what version is that. I dont remember seeing that in mine tho ill check. And yes i know for sure my original file was manual.
    May 2019
    Maine USA
    15
    4.4.2 Advanced view
    Do compare of a auto vs manual file for your os , all other things being equal , lots of differences between a flywheel (energy storing) vs a converter (energy stealing)
    Sep 2017
    736
    4.4.2 Advanced view
    I upgraded and mine absolutely says 0.
    I opened a stock auto file and its populated at 1200
    A manual file says 0
    So my file as stated did start out as a manual file.
    Hope this helps.
    Sep 2017
    736
    This seemed to have worked. No first start idle issie in park this time
