Results 1 to 18 of 18
Thread: Intercooler Pump Control
    Nov 2018
    19
    The major M157/M278 mail-order tunes include adjusted intercooler pump operation (lower setpoint temp), but this isn't available in VCM Editor. This would be a great feature for MB biturbo engines as they're prone to heat soak even at stock boost levels. Can we get aux pump control added to HPT?
    https://forum.hptuners.com/showthrea...s-on-a-Hellcat
    Nov 2018
    19
    Bump... does anyone know the table number for this? I tried to log the low temp coolant temperature and pump speed, but got no data. Currently it seems the pump is activated partially by throttle and I'd like to simply run the pump based on IAT, regardless of throttle.
    Oct 2017
    39
    i have looked at damos,it have a temp activation..you would need to start it very early to get benefit.
    Nov 2016
    39
    Log a ticket with HPTuners. I don't think they read these forums.
    Nov 2018
    19
    I did that, but was told they need the table number to add it.
    Nov 2016
    39
    Quote Originally Posted by Schnell View Post
    That's the same lazy response I got about cruise AFR. Not good enough considering we pay EIGHT vehicle credits for our vehicles. More effort in to continued development needs to be made. If it was 2 vehicle credits, I would accept that type of response but NOT when we pay 8.
    Oct 2017
    39
    what do they mean by table number ? how can i know a table number if i don't see it ?
    Nov 2016
    39
    Quote Originally Posted by samtuning View Post
    The table number must be something specific to the DAMOS that HPTuners use. They should NOT need a "table number" if they actually made an effort to look for the table. Very disappointing.
    Nov 2018
    19
    Bump!
    Oct 2017
    23
    Run Switch with relay to the pump on key on or on a switch you can control. Much Easier done many times. Also if its an earlier year separate the cooling systems. Hope that helps
    There are hundreds of maps. Support has been helpful even for myself to mention the same. If I know the table location I could specify and they will add as an available map. You can use a tool like WinOLS to identify a table and provide that to support for addition.
    Tuner in Training outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    30
    The map is available in Damos
    Nov 2018
    19
    Quote Originally Posted by outlaw_50 View Post
    Do you happen to know the map location that would help HPT add it?
    @outlaw_50
    Nov 2020
    30
    @outlaw_50
    3EE392 => Upper Threshold IAT for Activation intercooling pump
    3EE394 => Lower Threshold IAT for Activation intercooling pump
    3EE3A4 => Upper Threshold Transmission oil temp for Activation intercooling pump
    3EE3A6 => Lower Threshold Transmission oil temp for Activation intercooling pump
    3EE3B9 => Intercooler Efficency (IAT)
    Nov 2018
    19
    Thanks! I'll see what they say..
    I noticed that my IATs don't drop unless I'm on the throttle somewhat, regardless of IAT at the time. It seems like there may be a throttle or load component activating the pump.
    Nov 2020
    30
    Easier is to just to make it always pumping by making the intercooler pump directly connected to the switch ON position.
    Xstages Tuning and Performance
    Tuning inquiries:
    Email: jy8@hotmail.com
    Whatsapp: +971503383340
    Nov 2018
    19
    The tables have been added to the latest beta of VCM Editor. I'm playing with them but haven't seen much difference. IAT still only drops with throttle input while in gear... so maybe a certain minimum load %. Are there any tables you can see that sound like what I'm describing?
    I think the transmission oil temps are separate and meant for a transmission cooler pump activation.. but they have been added either way.
    Nov 2020
    30
    I connect the Intercooler pump directly to the fuse box so its always on when the switch is in ON position.
    That's the best way in my opinion
    Tuning inquiries:
