Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: 06 LBZ Duramax
    Tuner 04snake's Avatar
    Sep 2006
    Upstate NY
    75
    06 LBZ Duramax
    Just want to add a thread for those guys waiting like myself. The truck I promised to tune was actually an 06 LBZ, the owner had it since 05, hence my cornfuzion. Well we added the Banks intake and giagundo exhaust, just waiting to finish it up with a tune. I would be willing to be a beta tester for it and will have finished tuning my 99 SS and looking for the next challenge, good luck finishing it up, can't wait!
    - Stu
    Jan 2006
    Jupiter, FL
    33
    HPT,
    Do you guys have a timeline for the LBZ stuff?
    Keep up the good work,
    Kevin
    2012 CTS-V Coupe M6
    1999 Z28 M6
    28,298
    shooting for 1st quarter of next year.
    Advanced Tuner Boost's Avatar
    Dec 2006
    Florida, USA
    303
    I also have an '06 LBZ. It will be one of the first vehicles I tune. My question is, since it has a Bully Dog Power Pup now, will I be able to tune over it? Thanks.
    '12 Caprice PPV 6.0 L77 - daily transportation
    8.7 @ 84 (1/8 mile) bolt-ons
    '02 Silverado RCSB 5.3 L59 - regularly street driven
    8.2 @ 86 (1/8 mile) stock cam and spray
    8.6 @ 84 (1/8 mile) cam and heads no spray
    Our YOUTUBE CHANNEL featuring the Silverado
    28,298
    if thats an inline module it will probably need to be removed.
    Dec 2006
    Florida, USA
    303
    It's not a module. It's a tune that you upload through the OBDII port. No hardware. I do however have a small unit inline with the EGR/MAF harness. It modifies the signal to prevent a Check Engine light due to the EGR blockoff plate. How would this affect my HPTuner operation?
    28,298
    as long as bully dog doesnt lock the tune you should be able to read/edit it just fine. The egr thing shouldnt affect anything.
    Tuner alanderson1978's Avatar
    Apr 2006
    Blytheville, AR
    157
    I've been able to read after using Hypertech and Quadzilla programmers on various years.
    If you disable the EGR in HPT, is it effectively the same as an EGR blocker plate?
    2005 Sierra Z71 SLT CCSB (LM7)
    STS GT67, LPE GT 2-3, ASP Pulley, Delphi 42#, A'PEXi AVC-R, PLX SM-AFR, FLT Level 5 4L65E, PI Vig 2600, HP Tuners with 2-Bar SD OS (Plus some smaller mods)
    Support our Troops
    Dec 2004
    WI
    7
    You will still need a blocker plate. The EGR stepper motor is not strong enough to keep it closed.
    SWB Ex Cab K2500HD 04.5 LT/Amsoil B2B/ARE Tonneau/BedRug/Evans NPG+/LT235-85R16/Putco White-Out/VR-Straps/HIR 9012/Mag-Hytec Diff/Cat delete pipe/Al-ienator Trans/SD Rods/Racor Pre OEM/Lift pumps/OEM 3" Ext.Valance/MikeL Cooler
    Apr 2006
    Blytheville, AR
    157
    Thanks Jake. I'm not the one who needs, but a friend's got an 05 we're workin on, so he needs one. I told him I could spend his money faster than he could make it
    Where in WI you at?
    Support our Troops
    Feb 2006
    13
    Quote Originally Posted by Boost
    If you have loaded an ECM tuner on your truck, REMOVE IT (return to stock) before using a custom tuning system. If not, you can ruin your Bully Dog (Predator, SuperChips, HyperTech) and you will not be able to use it again correctly.
    "Casper" World's Fastest Production Diesel Pickup - 174.586mph Bonneville
    "Casper" - 2005 GMC 4x4, PPE GT42 and 2CP3, Mike L Trans, McRat tuning, 750+ rwhp - 10.65 @ 130 w/1.71 60'
    "Big Blue" - 2004.5 GMC 3500SRW, Mike L trans, PPE Tuning, 502 rwhp, 13.10 @ 103
    "Wendy" - 2006 GMC 4x4, McRat tuning, Mike L trans, 530rwhp, 12.50 @ 107
    "Blue Meanie" - 2002 Z06 Corvette, 440rwhp, 11.40 @ 121.
    Pat and Kat McSwain
    Dec 2006
    Florida, USA
    303
    Hello McRat. This is 4rotorcorvette from the Diesel place. I guess it's similar to using the Tech2 on the Bully Dog equipped trucks, it ruins the tune also.
    I wonder if they did it to prevent people from stealing the tune. I just want to see the before and after parameters of a properly tuned Duramax.
    Dec 2006
    Washington State
    96
    Actually you should be able to do a complete read with out disturbing any thing in the Tune. I have been able to look at some of the older hand held tunes. some one who is willing to sacrifice there newer box might be able to try also.
    What you may find is that HPT is un-willing to read the TCM after a bully Dog has been installed. I found that some times I would have to use the Pup to return it to stock then upload the tune I wanted to look at again. This may or may not help. In the end I just unplugged the TCM to get the read.
    What you DO need to remember is NOT to up load any changes before plugging in and returning the truck to stock with the hand held.
    Now on the new stuff where they are tuning on the fly I am un-sure if you will find any thing. I am not sure but am guessing they write the fuel tables in an un used area of the code and then just add a redirect line in the look up tables. Again I am un-sure and I do not hack the code ,HPT does
    This would be in line with the 'locking' some mentioned.
    To be clear I would not use a tune like this as a direct upload. I use them for educational puposes. I am looking for some others to see what different things each set does to get the results. From what little of the code we actually have access to there is not much to see.
    I must say once you start looking at them you see there really is not alot different from one to the other at times
    Good luck and be Careful!
    Hey McRat. I bet you had no idea I had this much fun
    Ellis
    Speed Secrets
    95 Z28 18* LTx
    95 Z28 LSx converion
    03 CCSB 4x4 D/A
    Feb 2006
    Panama City Beach, FL
    29
    Another user awaiting LBZ Tuning!
    2002 WS6 M6-454 LSx 918/1326
    2000 Camaro SS M6
    2000 WS6 M6->A4
    2004 Silverado SS
    2002 Grand Prix GTP
    1996 Impala SS
    1999 VW Pissant VR6
    1989 Trans Am WS6
    28,298
    Yup, Chris mentioned they are aiming for a March release at this point for LBZ as long as everything goes smoothly.
    Quote Originally Posted by foff667
    Will it have the RTT switchable OS when it is released?
    28,298
    not upon initial release.
    Feb 2006
    29
    Fingers crossed- I love 'em and I need 'em!
    2000 Camaro SS M6
    2000 WS6 M6->A4
    2004 Silverado SS
    2002 Grand Prix GTP
    1996 Impala SS
    1999 VW Pissant VR6
    1989 Trans Am WS6
    Sep 2006
    Upstate NY
    75
    So the latest release 2.1.16 doesn't have the LBZ support yet? I saw the email and got my hopes up!
    I talked the guy who has the 06 Duramax out of buying any Banks piggy back but he is about done waiting, any news on the beta? Is 2.1.17 going to be the beta of Duramax without RTT? Man if it is I gotta start begging now so I can keep this guy from going Banks!
    - stu
    28,298
    like I mentioned earlier the earliest LBZ will be publicly available is going to be march.
