Results 1 to 13 of 13
Thread: 2011 Ram 5.7 Hemi WOT
    Mar 2020
    33
    Someone with some experienceFull Throttle pull.hpl11th drive.hpt look at my long and tune please. If you look at time 1:58 and look at my Desired Lambda it shows to step down. The gear before it was commanding .87 at WOT at the same cells as after the shift but what cells are making it add more fuel and commanding .70. Im sure it has something to do with the Power enrichment but what do i need to change to level this commanded out?
    May 2018
    Germany
    589
    for the cahllenger there are two enrichment tables . wot and aircharge - not sure...
    I think when spark is dropped there will be other condotions for fueling.
    Mar 2020
    33
    So for what i have been able to tell on the two enrichment tables it uses whichever one is higher. So that is why i made them both the same. I dont have much timing in the vehicle because i do not have the fueling right yet that is why the spark is low right now also because its a hemi and they dont like timing on pump gas. There has to be something else there that i am missing
    Oct 2005
    baton rouge la
    411
    can you post the tune as well. Commanded PE can change based on aircharge and RPM so if you shift gears even at the same RPM you could be at a different aircharge. Without looking at what youre commanding, there is no way to know if its an issue, or doing as you command
    Mar 2020
    33
    Here they are again
    Aug 2017
    Quakertown PA
    481
    any Idea Why your IAT is 150 some odd degrees ?
    G3 Hemi Videos
    Mar 2020
    33
    Quote Originally Posted by PurpleRam View Post
    Because it was 96 degrees ambient outside and it was just sitting there idling before i logged it. The factory air intake is not the greatest.
    Oct 2005
    baton rouge la
    411
    Quote Originally Posted by darens View Post
    Here they are again
    IF you go to
    engine>fuel>power enrichment>aircharge. Open that tab, and you will see a commanded adder to your Stoic number. You can see your commanded enrichment is different for several of those cells vs being a single number no matter "load" Likely you are seeing exactly what is being commanded.
    Give this a try. I didnt mess with much just a couple of things that caught my eye. If youd like to post the stock file as well we can compare whats stock vs where you were.11th drive dms1.hpt
    Mar 2020
    33
    So i took a look over what you changed. All you changed was commanding 12.5 AFR across the hole map. I dont understand why i would add even more fuel on top of what i already had. I have already tried changing the delay and the enrichment rate in a different tune but it still had a step down in the demanded. I appreciate you trying to help because trying to get help on here anymore is like pulling teeth. But i will apply most of your changes and see what it does.
    Mar 2020
    33
    ok i applied the changes and still right at 4 seconds in wot it take the desired AFR @ 12.5 and lowers down to 10.4 :1.... Its just like clockwork right at 4 seconds. What else can i be missing
    Apr 2014
    706
    I have a hard time believing you haven't already tried this, as it's usually one of the first things folks do when tuning to make things more predictable and consistent. But you should really zero out your Catalyst Protection "FA COT/EOT Enrich" and "FA Enrich Max" tables. Odds are that's where your additional FA Enrichment is coming from.
    Mar 2020
    33
    Quote Originally Posted by B00STJUNKY View Post
    Man that fixed it. Thank you. I dont see how it was adding fuel in those conditions but it was. I zeroed it out and now it is doing what is commanded. Thank you i appreciate it.
    Aug 2017
    Quakertown PA
    481
    are you referring to Table ECM34200 ? Fuel>General>FA Limits ?
    Never mind , the tune I was looking at doesn't have table ECM34273.........
    G3 Hemi Videos
