Results 1 to 18 of 18
Thread: 2012 ram 1500 tune HELP
    Jul 2022
    I have a 2012 ram 1500 5.7 we put a stage 1 comp cam, mds delete and shorty headers. we also installed the phaser limiter. When trying to adjust the ve tables in speed density it seems like it makes very little or no change at all. ive been watching tons of video and reading articles trying to figure out the issue but nothing seems to help. I will log the vehicle pressure ratio and rpm create a histogram , copy and paste special -half but fuel trims are staying -16 ish all over. grant robinson 12 ram stock file.hptgrant robinson 12 ram stock file( KD VE changes).hpt
    stock file and current tune file attached ................... this is my first attempt and tuning anything
    Aug 2021
    Yorktown VA
    198
    Try this... I'm thinking this will set you straight with seeing your VE changes...
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    Aug 2021
    Yorktown VA
    198
    Even better yet,,, if you want to, you can load this up and try it out....its a slightly dialed down version of my current Ram tune. Or you can just use it as reference. Hope this helps....
    Aug 2021
    Yorktown VA
    198
    I didn't adjust your variable camshaft page under airflow because I didn't have the cam"s and limiter"s full specs so you may at some point adjust that entire page to your cam specs.
    Oct 2005
    baton rouge la
    411
    Need to disable ANN for VE to work. Looks like Spray-Cam Hell-Ram took care of that
    Sep 2023
    5
    Quote Originally Posted by white1 View Post
    Can anyone here help me with a 2012 Jeep grand Cherokee with a hokey sniper intake and a cam and a locked out vvt gear need a tune asap
    Oct 2021
    Allentown PA
    363
    Quote Originally Posted by Daltonsmith View Post
    Post Tune and a log if you have it,
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Sep 2023
    5
    Quote Originally Posted by rays04gtx View Post
    How do I post the attachment it want let me
    Oct 2021
    Allentown PA
    363
    you have to hit the "go Advance" Button and then you'll see this part of the page, hit the button and post a tune,
    or just send it to my email,
    rays04GTX at yahoo
    Sep 2023
    5
    I emailed it to you
    Aug 2021
    Yorktown VA
    198
    You can try this...I don't know which cam you have but assumed a stage 3 or higher given that its locked. I have stock injector data input so change as needed there. I have it set to go into closed loop so change that as well if your set-up requires open loop. I used my VE tables so you may need to adjust these tables as you go. I have your cam set up to chop nicely if its capable of doing so. Good luck!
    Oct 2021
    Allentown PA
    363
    I emailed it to you
    the file extension didn't work, not sure why.
    Sep 2023
    5
    its the thumper cam nsr i think somebody messed with tune before i got it and i just rebuilt it holley sniper intake 3000 stall and comp cam nsr Camshaft, Thumpr NSR, Hydraulic Roller, 268/295 Advertised Duration, 0.510/0.505 Lift
    Sep 2023
    5
    thank you
    Nov 2023
    6
    Help on 2009 ram 1500 cam upgrade tune
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    i did a mopar 6.4 cam with mopar high performance springs, hellcat 6.2 oil pump, and an mds delete what tune would be the best for me to run the truck idle correctly with a nice decent chop sound? its my first time tuning i got the mpvi3 and would like to flash a nice tune.
    Aug 2023
    Hey spray-cam how can i get hold of you need some advice on a 2012 5.7 hemi that i deeted the mds with non mds cam and non mds followersdoesnt want to run at at up until 2000 roms and real rich
    Dec 2023
    Quote Originally Posted by Andrevr View Post
    I'd be happy to help you out. Post here what you need. (file, mods ect)
    Aug 2021
    Yorktown VA
    198
    you can mouse click on my name where you see it in any thread and select private message. Or if you need any tuning assistance, you can email me at [email protected] . This way you can attach the tune in need of work and we can go from there.
