Results 1 to 10 of 10
Thread: Intake Valve Temperature
    Advanced Tuner TiredGXP's Avatar
    Jun 2007
    Sherwood Park, AB
    259
    There's a number of tables in the LS4 that refer to Intake Valve Temperature - specifically in several of the Transient Fueling tables.
    Can anyone comment on how the ECM is calculating the Intake Valve Temperature value?
    2005 Grand Prix GXP - 5.3 LS4 - HP Tuned, MF catback, 1.8 rockers, K&N, Some day I'll finish putting the LS6 intake on
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    The IVT and Injector Tip Temp values reported seem to be VERY low on the logs I have.
    Always Support Our Troops!
    it's a mathematical model that uses ECT, MAP, RPM, spark, afr and also alcohol mix.
    I count sheep in hex...
    Jun 2007
    Sherwood Park, AB
    259
    Quote Originally Posted by Chris@HPTuners
    I figured it was something like that, maybe even including factors for the effect of fuel boiling off the back of the valve. Any chance that you can share the model with those of us who don't look inside ECM's?
    its a linear model with coefficients that are obtained by experiment i guess. not something you could easily "tune"
    IVT = a.X + b.Y + c.Z + etc...
    Jun 2007
    Sherwood Park, AB
    259
    Thanks Chris, this helps
    Just trying to gain an understanding of how GM determined a value that can't really be measured in a vehicle, but drives things that I can tune.
    A linear function you say.......time to dust off the regression analysis text and see if I can come up with an approximation.
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's a test - this is only a test:
    Put the car in Open Loop.
    Take your IVT values starting at 1.0 at your current outdoor temperature for the day and add .01 to them (with all other O/L AFR modifiers set to 1.0) in increments vs IVT temperature. Now monitor Commanded AFR and IVT and see how well they match.
    Jun 2007
    Sherwood Park, AB
    259
    For those who may be interested, I came across a SAE Technical paper today that discusses IVT modeling and transient fuel compensation in some depth. I expect that it will take a while to digest the info contained in the document.
    Here's the link for anyone who is interested
    **Warning Math Content**
    http://delphi.com/pdf/techpapers/1999-01-0553.PDF
    Baltimore, Md
    1,454
    Quote Originally Posted by TiredGXP View Post
    Anyone have a copyof this PDF?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Sep 2021
    Kentucky
    1,839
    Nice find.
