Results 1 to 7 of 7
Thread: Tuning the Cooling System
    Feb 2004
    Falls Church, VA
    14
    I've done a little bit of modification to my cooling system and am trying to figure out how to tune my fans for the best performance settings.
    All I've done is replaced the stock 195* thermostat with a 160* and spliced in SLP'S Manual Fan Control Switch (which works perfectly btw). To make sure my 160* stat was actually opening at 160* I opened the bleeder so check if coolant came out steadily (meaning the stat was open), sure enough it opens right at 160* and works great too. But there was one small problem, the SES light came on and after scanning I found out it was
    P0128 Coolant Thermostat
    After the SES light came on my temperature gauge dropped down to zero and ceased function all together. Also, both my fans immediately came on I guess as some kinda fail safe to keep the car from overheating. But the stat never stopped working, and coolant flowed as normal! Once I cleared the SES light everything went back to normal and the temp gauge worked again... Should I disable P0128?
    Also, my fans are set to come on at 181 and go off at 174 (stage 1) and 190/185 (stage 2) is that a good setting?
    2008 Cobalt Sport Coupe 2.4L A4
    K&N Typhoon Ram Air Intake
    CA 2.5" Header and Down-pipe w/ cat
    Aug 2004
    Ewing, NJ
    20
    Re: Tuning the Cooling System
    I had the same issue with that code and I deleted it. As far as the fan temps, what I did was to figure out the relationship of stock settings to stock thermo and keep that same ratio. I don't know what I have off hand but I know I have fan 1 set at 181on 176off.
    2002 Pewter V6 Camaro M5&&&&Quickest stock-motor N/A V6 4th Gen F-body.&&2nd Quickest N/A V6 4th Gen F-body overall.&&&&mods: Gear, !weight reduction, tuning&&&&Fear the Gear. 13.585 @ 100.05 1.827 60
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    The problem is our cars do not like 160*. The PCM thinks it is too cool, sets the code, and drops off the indicated temperature. I spoke with the people at Hypertech and they confirmed this. I went to a 180* and it works great.
    This all happened before HP Tuners so I never tried to delete the code and do not know if deleteing the code will keep the temp gauge working or not. ANother option is to put a resistor inline (search Firebirdv6.com). with the temp sensor but this will effect other things. Hope this helps.
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    post your OS number or email me your bin. I'm sure we can mod the test for this in future.
    I count sheep in hex...
    Aug 2004
    Ewing, NJ
    20
    After I dropped the Coolant Thermastat code, the temp gauge never went out again.
    Apr 2004
    Tampa, FL
    425
    Well, I just need to put the 160* back in, delete a code, and I should be fine. Thanks.
    3.6 V6
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    28,320
    Quote Originally Posted by Chris@HPTuners
    fwiw i had this code in my gtp as well not sure if anyone sent you your bin but i sent in my file to support a few days ago if you need it for this as well.
    Bill
Similar Threads
  1. Correct Tuning Procedures
    By Jax5.7 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 05-12-2022, 11:51 AM
  2. Your Guide to a good tuning experience
    By Bill@HPTuners in forum VCM Suite General
    Last Post: 10-27-2010, 11:59 AM
  3. HP Tuners VCM Suite v2.2.0 is Now Available!
    By Chris@HPTuners in forum VCM Scanner
    Last Post: 12-24-2007, 09:23 AM
  4. Service Brake System ... (tuning help)
    By Flyer in forum GM V8 Tuning - Miscellaneous
    Last Post: 11-19-2005, 07:02 PM
