I have been involved in a thread about using the P/N Rev Limiter to help launch at a consistent RPM. Here is another idea.
Would it be possible to set a Throttle Possition Limiter based on the same criteria as the P/N. In my car, it seems to be 0 mph.
The way this could work is if it sees 0 mph, the max TP would be "X". You could set "X" to what ever gives you your proper launch RPM.
It would be a lot more steady RPM then you would get with either a fuel or spark cut off. Just an idea.
