We didn't get Knock Sensor Calibration!
I really need this! Is there any way we can get this????
2013 Jeep Wrangler JK
3.6 V6
More MODs than Stock
2018 Ram rebel
5.7 Hemi V8
Stock
Originally Posted by arthansen
Big muscULLZ keith money seems to have forgot a few things..
the table that i had to edit to correct the "reduced engine power light" i was getting for the TPS check on electrionic TB cars is gone now too???
ahh growing pains.. I am sure they will take care of it though
-Bill
2000 Camaro V6 Boltons and a tune
While the guys at HP Tuners think about getting us the controls we need, I have another related question.
I set up a log file and logged all the Knock related PIDs. However, I can not make any sence out of what they mean.
I logged:
RPM
TP
MAP
MAF
Ignition Timing Advance
Knock Retard
Knock Sensor Voltage In Range - Front
Knock Sensor Voltage In Range - Rear
Knock Sensor Voltage Out of Range - Front
Knock Sensor Voltage Out of Range - Rear
Vehicle Speed
I got some knock retard and I got readings in the 4 sensor voltage cells but never anywhere near eachother. If I had KR, all those other cells were zero. When the Voltage cells had readings, no KR.
The In range readings were from 0-150 and the Out of range readings were from 0-10. THese readings were only in a small percentage af the cells and go up and then disapear over a period of about 3 seconds.
What does all this mean???
3.6 V6
2018 Ram rebel
5.7 Hemi V8
Stock
the P1514 was my mistake, sorry. It is back in now. Send me email with your cable ID and i'll put an update up for you.Originally Posted by Missing2
Knock sensor calibration wasn't on the list for v6 engines this release.
I count sheep in hex...
Bill, when it comes to the HPT V6 calibrations, It's all Chris.. Chris is the V6 code guru.
We got this guy Not Sure, ...
OK, I will keep my hopes up for 2.0.
Please look at the third post again. What exactly does the Sensor Voltage PIDs mean?
3.6 V6
2018 Ram rebel
5.7 Hemi V8
Stock
Knock sensor cal is on the list now
The counters you are looking at are used in the decision to set P0325, P0327, P0332 in regards to the acceptable knock sensor circuit voltage ranges. If you aren't seeing the DTC then no probs. Looking at a few bins the threshold is set at 250.
Chris..
Originally Posted by Keith@HPTuners
;D but its more fun to mess with you keith ;D
Its not a huge deal chris, Just something I noticed was missing.. no apology nessisary..
-Bill
Thanks for the quick responce. You guys are great.
I will be starting a post in VCM Suite General called:
"when are we going to see 2.0???? "
JK
3.6 V6
2018 Ram rebel
5.7 Hemi V8
Stock
no worries, just keep little smilies at the end of each post in the short term though.
Chris...
