Page 1 of 14 1234511 ... LastLast
Results 1 to 20 of 264
Thread: Known LNF 2.0T issues that need to be addressed please post here!
    28,312
    Exclamation Known LNF 2.0T issues that need to be addressed please post here!
    As requested here http://www.hptuners.com/forum/showpo...2&postcount=83 please post your experience as to what issues are most important to you guys here.
    Make sure you attach any pertinent .hpt and .hpl files
    I'll start off with one I've heard alot about
    1. Scanner PID for the stock wideband O2 sensor & fuel pressure PID(if its even possible)
    thanks,
    Bill
    28,312
    2. here is one of the scans turbofreak posted http://www.hptuners.com/forum/attach...0&d=1202617062 regarding the boost limiter issue many are facing at around 18 psi of boost or 6300 rpms
    3. correct me if I'm wrong but it appears that there may not be a MAF voltage PID which would probably be good to have in tuning the LNF maf table.
    4. cat over temp control
    5. boost control via pcm
    6. the ability to swap to a 3 or higher bar map sensor as many are already on the edge of the 2.5 bar map.
    Aug 2007
    503
    1) rpm control, still stuck at 6300rpm
    2) boost control
    3) eliminate 23psi boost ceiling? ability to stretch the tables to accept a 3 bar sensor maybe?
    4) wideband/direct injection fuel pressure pid
    5) cat over temp control
    6) cooling fan control
    7) 50+ ve tables other cars have
    nice things to have but not necessary
    1) no lift to shift and launch control from cobalt ss
    28,312
    Quote Originally Posted by shabby
    2) boost control
    Can you post your latest .hpt file & scanner log showing the 6300 rpm limit?
    Advanced Tuner 405HP_Z06's Avatar
    Feb 2004
    Arlington, Texas
    270
    Torque management tables.
    Automatic HHR SS is boost limited in 1st and 2nd gears. Surely there's a table for this.
    Auto trans tables
    Aaron
    '03 Z06 Corvette - The Normal Stuff.....
    EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
    EFI University Evangelist
    Quote Originally Posted by Bill@HPTuners
    This would be a great start ... had it on the DashHawk for over a year.
    Jul 2007
    Honeoye,Ny. Boondox son. Shoot guns out my back door. noone cares.
    627
    Cam timing PID,
    torque managment strategy concerning cam timing?
    ETC tables
    Me love boost long time.
    quick question, the code seems to have provision for two MAP sensors and a Baro sensor. How many MAP sensors are there actually fitted? Is there one in the manifold and one on the turbo side of the throtttle body as well? and then an ambient (barometric) pressure sensor on the turbo inlet side or some other place?
    Also looks like both the pressure side sensors are 2.5bar stock and the baro sensor is a regular 1bar sensor.
    I count sheep in hex...
    Aug 2007
    503
    Maybe this will help, theres an additional tmap sensor fitted on the intercooler pipe.
    Bill im far away from my laptop, im sure baldturbofreak can provide you the hpt/logs you're looking for. You can even see in the log you posted before he's maxing out at 6300rpm.
    Btw in what situations is the ecm controlling the bov? Simply in regular driving or to bleed of excess boost?
    Jul 2007
    627
    Here is some logs, im not sure which have me bouncing into the redline.
    but the 23psi one I beleive shows the ETC doing it's magic.
    Jul 2007
    627
    The Baro sensor is on the board of the pcm? Like a honda?
    I hope the code could be modified for a different T-map & Map someday.
    Feb 2004
    Arlington, Texas
    270
    Quote Originally Posted by Chris@HPTuners
    That would make sense according to the diagram shabby posted.
    BARO sensor is built in to the PCM (Ambient pressure sensor)
    One before the throttle body
    One after the throttle body
    Aaron
    Jul 2007
    627
    here's what Ive been runnin'
    Oct 2004
    Baton Rouge
    8
    They are both possible. I currently can monitor both with my Aeroforce Intercepter gauge, so the PIDs are there.
    28,312
    Yeah, I had heard about the wideband PID, not the fuel pressure.
    IAT2...post i/c map/temp
    Thanks for the pic and the file, helps a lot. Usually the BOV would only be used to bleed off boost when the throttle is closed rapidly or in some cases if some conditions for surge transient are met (to protect the turbo). Normally the BOV is either open or closed so it's not generally capable of actually controlling boost, the wastgate control does that.
    This may help ....
    Jul 2007
    627
    I'm going to take it to 7500rpm tomorrow and make it beg for mercy. I will post the log. (I had some digital help from a friend)
    Aug 2007
    503
    Bill/Chris any clue why baldturbofreak was still limited to 6300rpm even after the changes that he made to the rpm limits?
