Results 1 to 11 of 11
Thread: cot on/off?
    28,774
    cot on/off?
    i noticed there no on/off cot like for v8's...what have you guys done to counteract that?
    Re: cot on/off?
    there is supposed to be an enable temp, that appears to be broken.
    let me check it out.
    Chris...
    edit:
    If you set the COT AFR higher than your PE (ie. 14.7 across the table) it should effectively disable it as well. As the PCM will always use the richest.
    Regardless i will fix the enable temp.
    I count sheep in hex...
    Aug 2004
    Ewing, NJ
    20
    Re: cot on/off?
    When I set the A/F to 14.7 on the COT table the car wouldn't run. I set it to 12.7 where it dropped below 13 and it ran fine. Shaved two tenths off ET. A master on/off switch would be ideal though.
    2002 Pewter V6 Camaro M5&&&&Quickest stock-motor N/A V6 4th Gen F-body.&&2nd Quickest N/A V6 4th Gen F-body overall.&&&&mods: Gear, !weight reduction, tuning&&&&Fear the Gear. 13.585 @ 100.05 1.827 60
    Jan 2004
    37
    Re: cot on/off?
    What does this do for you?
    Mar 2004
    Germantown, MD
    362
    Re: cot on/off?
    Quote Originally Posted by Little G
    I concur,
    "Make it so" -picard
    :huh2: i dont even really watch star trek..
    ohh well.. add it to the features to add for the next release
    -Bill
    2000 Camaro V6 Boltons and a tune
    28,774
    Re: cot on/off?
    Quote Originally Posted by Missing2
    I concur,
    wheres the im with stupid smiley when you need it
    Re: cot on/off?
    there is no master on/off switch in the code guys, the enable temp is the thing to use.
    Mar 2004
    Germantown, MD
    362
    Re: cot on/off?
    Quote Originally Posted by Chris@HPTuners
    ??? please give a clear explanation on how to do it then please
    -Bill
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    Re: cot on/off?
    The V6 does not have temp control. All we have is AFR based on fuel flow. Either the temp control or the on/off would be nice.
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Re: cot on/off?
    the enable temp bug has been fixed, we will be making this available in 1.6 (or sooner if you email us your customer ID).
    Apr 2004
    Tampa, FL
    425
    Re: cot on/off?
    E-mail sent. Thanks.
    3.6 V6
    2018 Ram rebel
    5.7 Hemi V8
    Stock
Similar Threads
  1. ford pid list
    By beerman in forum OBD-I & OBD-II Hardware And Communications
    Last Post: 12-06-2016, 04:20 PM
  2. COT Question
    By Cyclone Chris in forum GM V8 Tuning - Engine, Gas (Gen 4)
    Last Post: 12-09-2006, 05:23 PM
  3. Commanded AFR and COT questions
    By manxam in forum GM L4, I5, I6 Tuning - Engine
    Last Post: 09-08-2006, 10:09 PM
  4. COT on/off via calculated exhaust temp?
    By Bill@HPTuners in forum VCM Suite General
    Last Post: 12-19-2005, 12:28 PM
  5. COT toggle not working on 04 GTP
    By WhiteHawk in forum GM V6 Tuning - Engine
    Last Post: 07-29-2004, 09:39 PM
