Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 174
Thread: 96-97 vortec trucks
    Feb 2007
    SC
    61
    96-97 vortec trucks
    I have a vcm suite package, what do I need to program the early obd II vehicles (1996-97)?
    Jul 2005
    18
    The 96-97 trucks arent supported.
    You need to swap your BLACKBOX Vortec 96-97 PCM for a 411 PCM and use a base calibration file for a 2001-2002 GMC Savana or CHev Express van as these vans used teh older Vortec 305,350 and were conrolled by the 411 PCM.
    You sinply push the pins out of the blackbox PCM and insert them into teh correct position of the newer 411 PCM, plus tehre are a coupel extra wires you will need to run.
    This swap will allow you to use HPTuners to tune teh 96-97 trucks.
    More info here.(long read but its all there)
    http://www.pacificp.com/forum/viewtopic.php?t=3240
    Get the pin assigmnet charts for a 1997 truck, and an 01-02 van and start swapping.
    Register at this site http://www.pacificp.com/forum/index.php and PM a guy named Lextech, send him an email address, he has a sheet he can email you that has ALL the exact changes for the 97 truck 411 swap. There are a couple small differences between all the years of early vortec trucks.
    If you want to get BIG power from a Vortec smallblock, you'll need to swap in a GM/Mercruiser Marine Intake manifold. it uses a conventional fuel rail/injetor setup that is OUTSIDE the intake plenum(unlike the stock Vortec intake).
    I did this intake swap on a stock longblock Vortec 350 and theres no more over 5000 rpm power dropoff.
    http://www.pacificp.com/forum/viewtopic.php?t=317
    peace
    Hog
    Feb 2007
    SC
    61
    Thanks for the info.
    Sep 2002
    Chicago, IL
    6,397
    whats the service # for a 96 and 97 PCM? I think we can support them, we just dont' have any PCM's.
    We got this guy Not Sure, ...
    Oct 2004
    Huntingtown, MD
    200
    Quote Originally Posted by Keith@HPTuners View Post
    SERV # 16229684
    This is from my truck a 97 C2500 5.7L 4L80E
    Phil K.
    02 Camaro SS 5.7L LS1
    01 Silverado 1500HD 6.0L LQ4 4L80E 78/75 turbo with Flex Fuel
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    The 1996 5.7 C1500 pcm service # 19186080.
    Russ Kemp
    1996 - 1997 Vortec Trucks (4.3L, 5.0L, 5.7L, 7.4L)
    OSID --------- PCM#
    16256445T - 16244210
    16256455T - 16229684
    16232915T - 16244210
    16235505T - 16244210
    16237015T - 16244210
    16243345T - 16229684
    9378495T - 16244210
    16187577T - 16244210
    16204025T - 16229684
    16227245T - 16244210
    1998 - 2000 Vortec Trucks (4.3L, 5.0L, 5.7L, 7.4L)
    OSID --------- PCM#
    16265175T - 16263494
    9365085T - 16263494
    9355699T - 9366810
    9365095T - 9366810
    16263425T - 9366810
    9360505T - 16263494
    I have another 50 or so for 1996 to 1999
    i am very interested in support for these
    plus iirc the s10's/blazers ran the same pcm (4.3)
    that and there is no other tuning package i'm aware of except tunercat that will do them (and thats not really an option anymore)
    Advanced Tuner n0dih's Avatar
    Mar 2006
    Cherry Valley, IL
    391
    Keith, I have one if you need one, I work in Libertyville if you want to meet and pick it up. I drive through north Suburbs daily. I have a spare I don't need right now.
    They are a goofy one, closer to the 96-97 PCM than the 98-00 Black Box PCM's....
    Feb 2006
    South Carolina
    1,525
    I would be happy with just scanner support, if I had to pick one or the other!
    Jaime
    Mar 2006
    Cherry Valley, IL
    391
    I spoke with B&B (home of AutoTap) and they did say they were seriously looking at finally fully supporting the 96-97 Black Box PCM's.
    So politely talk to Joe Ebner about it (the online chat) and see if they have started.
    Honestly, inside it is closer to a 96-97 LT1 PCM than any I have seen.
    Hey you have only seen the inside of one of those.
    Mar 2006
    Cherry Valley, IL
    391
    They are a "funky" one as compared to most 98-up PCM's....
    Out of my mind, be back in five minutes...
    48
    Wow, that looks a lot different than the 98+ black box PCMs. Does it actually use two flash chips? Sort of looks like it from the photo. The datalink controller and hardware drivers are a lot different, too. Individual transistors and different drivers instead of the usual quad drivers in the earlier and later computers. Weird...
    Old rusty 88 Camaro
    350 w/ Edelbrock victor EFI intake + 1000 CFM TB
    '279 PCM with a custom tune and code patches by me
    TKO 500, 1LE performance package, etc...
    Mar 2006
    Cherry Valley, IL
    391
    Yes, these look more like a 94-95/96-97 LT1 PCM.
    Dec 2008
    os systems
    any talks of 123 bar conversion for 98 vortec. I have been waiting years for vortec support now that I have it I want more. I have a 383ht with powerdyne blower. Believe it or not the spyder has done quite well so far but i like my engine so I will be upgrading the fuel injection. When I do i would like to tune it the RIGHT way.
    Mar 2006
    Cherry Valley, IL
    391
    If GM didn't make it, it isn't going to happen.
    Best thing to do is swap to an 0411 PCM and use the "custom" OS's there. But as for the old BB PCM's, not likely going to happen.
    Talk to Lextech on it, he has done one and by far best thing you can do.
    28,303
    Quote Originally Posted by ws6 View Post
    Not really.
    Oct 2004
    Huntingtown, MD
    200
    I really hope we can get support for the 96 and 97's. Just simple parameters like the 98-00 vortec's have.
    Phil K.
    28,303
    Quote Originally Posted by pknowles View Post
    Scanner or editor support? As far as I can tell the 99-00 have nearly as many supported parameters as the early LS1 pcm's.
