Results 1 to 8 of 8
Thread: vats disable
    Jan 2004
    Tx
    24
    vats disable
    i need to turn it off and my only options are
    serial
    pwm
    none (but i cant select it)
    2000 pontiac firebird a4: whisper lid, !maf, ls6 springs & retainers,manley pushrods,tci ssf 3200, 3.42 lsd,Ta girdle,gt2cam,fan switch, lca,stb. installed and tuned by Texas speed & perfomance
    Oct 2002
    206
    Re: vats disable
    What are you working on ?
    OK, I see you have a 2000 Fbody in your Sig....
    I was told that Serial choice would disable the theft fuel enable...
    I use 99 and 2000 GTP code and this has VATs disabled already.
    Loyde
    Jan 2004
    Tx
    24
    Re: vats disable
    im get p1629 the security lights keeps flashing and car wont start
    Oct 2002
    206
    Re: vats disable
    Quote Originally Posted by Nightrida
    Did this happen after a flash to the PCM? I know there was some problem with the VATs on 1.5 and a email was sent out indicating for V6 users to download 1.5.1...
    Loyde
    Sep 2002
    Chicago, IL
    6,411
    Re: vats disable
    What version of software are you using?
    We got this guy Not Sure, ...
    Jan 2004
    Tx
    24
    Re: vats disable
    i went from 1.4.6 to 1.5.1
    i never loaded 1.5 because of the email.
    i am also having a problem connecting when trying the use the flasher but the scanner works fine.
    Oct 2002
    206
    Re: vats disable
    You cannot use the VCM Flasher if the Scanner is open.. So close the scanner, then open the Flash to make the changes to the VCM.
    Your going to need to detail more of your problem to figure out what is wrong in the VATs area.
    Can you put the stock file back into the VCM and get the car started?
    Why do you need VATs disabled on a Fbody that has a BCM to supply the VCM with the theft fuel enable signal?
    Loyde
    Jan 2004
    Tx
    24
    Re: vats disable
    vats is cool now . one of the wires in the ignition switch had broken. so a new switch and a pair of keys and i am rolling again.
Similar Threads
  1. Can I disable the VATS and get rid of Service Column Lock problems on Vette?
    By Backside180 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 09-23-2007, 10:16 AM
  2. V6 Vats disable 99 alero
    By LSR in forum VCM Editor
    Last Post: 11-06-2006, 02:49 AM
  3. 2001 Olds Alero VATS disable
    By NickG in forum VCM Editor
    Last Post: 10-22-2006, 11:48 PM
  4. How do I disable VATS?
    By Screamn03 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 09-16-2004, 09:30 PM
  5. 1991 Corvette CCM to ECM Communication Questions
    By vettxtc in forum OBD-I & OBD-II Hardware And Communications
    Last Post: 04-11-2004, 08:55 PM
