Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 147
Thread: GM LNF Stage Kit PCM Read
    Jul 2007
    Honeoye,Ny. Boondox son. Shoot guns out my back door. noone cares.
    627
    The logs posted appear to flatline at 255kpa
    Me love boost long time.
    Aug 2008
    46
    But it is now a 3 bar sensor if I'm not mistaken. Doesn't that change the definition of the 255kpa apparent reading or am I off on that? Still learning this stuff.
    Aug 2007
    503
    Quote Originally Posted by Baldturbofreak.com View Post
    It almost flatlines in the previous gear too but at a lower reading, so i think 22.5psi is what its set at. Im sure once we see a scan from a 5spd solstice we'll see higher readings since it makes more torque than the hhr.
    Jul 2007
    627
    I wonder if it's beign interpreted correctly since the op system has been changed
    Aug 2007
    503
    If the op system was changed that drastically i doubt you'd be able to read it and manipulate it, its almost like it wasn't changed to read those sensors properly. Maybe all gm did was change the desired air load and that's it?
    The new sensors just report a lower boost reading to the ecm, i doubt it would freak out since the maf tells it exactly how much air its ingesting.
    Anyway we'll find out soon enough.
  6. #26
    Jul 2007
    627
    Quote Originally Posted by shabby View Post
    hahahha man that would be so messed up.
  7. #27
    Mar 2008
    34
    The Maf tables are scaled lower than the stock tables.The long term fuel terms are also positive 10-14 percent as well after seeing some street datalogs.
    It will be interesting to see what others have datalogged.
  8. #28
    Advanced Tuner dont_blink's Avatar
    Feb 2008
    Denver, CO
    466
    I bet the fuel trims are at 0, but our scanner won't read the new OS correctly. That wouldn't make sense that the PCM has to add that much fuel in to compensate for programming. Unless GM REALLY screwed something up lol.
    RSG Offroad
    Jeeps. Jeeps. And more Jeeps. Oh and Jeeps too.
  9. #29
    Jul 2007
    627
    Or those logs came from a car with an intake.
  10. #30
    Tuner in Training davytudope's Avatar
    16
    sent a couple logs and the file to support@hptuners
    ps i have the gmpp upgrade, 2007 sol, 5sp
    2007 solstice gxp:gmpp; turbo upgrade, cai, PAW; intercooler, pipes, z0k; rear sway bar, rear brace. magnaflow, 18x9 ultraleggeras, 275 kumho xs, brake pads, kw v3's w/6k springs, energy suspension bushings, hp tuners, solo high flow cat
    TEAM FAIL RACING
  11. #31
    Aug 2007
    503
    Post some logs here too
  12. #32
    Advanced Tuner 405HP_Z06's Avatar
    Feb 2004
    Arlington, Texas
    270
    .….and the tune file
    Aaron
    '03 Z06 Corvette - The Normal Stuff.....
    EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
    EFI University Evangelist
  13. #33
    28,319
    The one that was sent to us is actually already a supported definition so maybe we got one an just didn't know
  14. #34
    16
    i'll call the people that did the tune tommrow to see if the file that i have is with or without a tune. i dont have my computer on me so i cant see what it is. i'm on vacation visiting family. i got the gmpp turbo upgrade and a good tune done. christmas gift for the car.
    TEAM FAIL RACING
  15. #35
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    hmm I"m interested in seeing what PCM changes gm did here.
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
  16. #36
    Aug 2007
    503
    With the "learn down" code disabled and "no lift to shift" code added i'm sure Chris will be able to see those differences between the stock file and the gm tuned file. And hopefully these feature will get into our hands soon enough
  17. #37
    Jul 2007
    627
    I wonder how much the BCM plays a role in the no lift shift.
  18. #38
    16
    i uploaded it to the repository. awaiting approval.
    it was a stock gmpp lnf turbo upgrade file. no tuning.
    TEAM FAIL RACING
  19. #39
    Mar 2008
    34
    NOPE-ALL STOCK AIR BOX....THE VEHICLE IN MENTION NEVER HAD FUEL TRIM ISSUES.
    Like I said,in time we will see a trend here I imagine
  20. #40
    Sep 2006
    Arizona
    600
    Quote Originally Posted by fr0stb1t3 View Post
    There's one that says he will hook it up to HPT today on the Solstice forum, but no one else has spent the money on one yet. Most of the people with HPT to check, don't want to spend the money until they know for sure that HPT works.
    Post 184
    I have unlimited credits for the LNFs, someone should let me know because I can read for free. Any car any year.
