I know this has been beaten to death but i just want to make sure that everything i am about to do is correct. I am working on a 2001 silverado with a 4.8 and i am about to start tuning the VE tables.
So far I have disable the mass air flow sensor by set the value to 0, disabled the PE by setting it to 640, and copied the high octane table to the low octane table.
Next I will flash these updates to my tune I will warm up the engine then open the scanner and reset the LTFT then go for a drive and try to hit all the cells that I can.
If they are all below 10 I copy the table and add it to the main VE table in the tune.
Next i will go back and create another log and then take the STFT and add them to the VE table again until they are all about 0 in all the cells.
Then I will re-enable all the stuff that I disabled and my VE table should be pretty close.
Is there anything else i need to do? Or is there anything I did wrong, or should i do differently?
