Are the VE tables calculated at the same temperature as the cranking VE tables? Is the Cranking VE calibration temp the outside air temperature?
1998 Camaro Z28 M6: SLP Lid, Adj. Panhard, SFCs, CAGS!, Hotcam, Hooker Shorties, Katech Tensioner, Catback with Dynomax 17221 3\" Muffler, Mobil-1, Bosch +4s, 160 Stat, !EGR, !MAFless, !FRA, S3 TB
TTT
the VE table, is not a "VE" in the true sense, the cranking VE is a true %.
the real units of the VE table are grams.Kelvin/kPa so you can see it includes a temperature component (linear) in it.
In 2.x we will allow you to view the VE table in either % or g.K/kPa
I count sheep in hex...
Very cool. Thanks!
I don't suppose you could shed some light on the AF ratio PID that can be used with narrowband. I was wondering if this is an AF ratio that the PCM calculates based on the amount of air and fuel it "sees", because it seems pretty accurate...I think.
I've always thought that it just displayed the commanded afr found by stoich/pe. Maybe I'm thinking of something else though.Originally Posted by AnotherUser
98 M6 TA, mods: tsp torquer(233/233 .589 112), Patriot golds, ls6 oil pump, ls6 intake, tsp lid, pacesetter LT\'s and ORY, magnaflow, fra, HPTUNER!
No. There is another PID for commanded AFR.Originally Posted by luv2spd
