Results 1 to 7 of 7
Thread: "paste special" and secondary VE
    Las Vegas, Nv
    64
    When running off the secondary VE, are the values in the AFR% in the scanner histogram accurate?
    I know the secondary VE has a different resolution than the primary. However, it doesnt look like the histogram picks up on this. Meaning there will be values for 1200x25 when the secondary doesnt disply 1200x25 (rpm x map).
    So i guess to clarify the question: when running off the secondary VE and logging AFR%, can i just copy the whole histogram table and "paste special" -> %-half on the secondary VE and have it come out correct? or will i have to copy each individual % and paste it to the appropriate cell?
    2000 Trans Am WS6 - Bright Red : 12.36 @ 110 - 1.832 60
    228/232 .571/.588 113 LSA | JetHot LTs | Yank ST3500/2.5 | SLP lid
    Jul 2004
    1,579
    Re: "paste special" and secondary VE
    Here is how Ken suggested I do it (IIRC), copy the values from your histogram and paste it on to your Primary VE (I didn't use the 1/2 % option). Then manually copy the coresponding tables from the Primary to the Secondary. Seems to work good.
    Oct 2004
    Orlando FL
    770
    Works too slow. How about adding the standard interface of the Ctrl or Shift keys. For instance, click the first row, then shift-click the end row to select the entire range. Or Ctrl-click on each row, to highlight all the individual rows at once, then paste them to the secondary with a single Paste operation.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
    Indianapolis
    166
    Real dumb question, where is my secondary VE????
    I only see primary VE vs RPM vs MAP under engine > airflow > general
    2002 Z51 C5 MN6 Coupe&&SuperMaxx Headers, Vararam, Ti Exhaust
    Nov 2004
    Houston, TX
    140
    Quote Originally Posted by BQuicksilver
    secondary is only for 98-00 users... keep on keepin on with your primary you lucky bastard!
    2002 Quicksilver Corvette Z06
    And then...
    Las Vegas, Nv
    64
    Quote Originally Posted by 12secSS
    for now, i have just been taking the rows I need for the given resolution and pasting them where i need to in the Secondary VE. I was told that the .5 (other part to the histogram resolution) was just interpolated by the pcm. So far its working alright
    except for the fact i am having trouble pasting in the "90" row of the table - it raises the ve the way it is supposed to but when i hit save, it doesnt keep those changes...i wonder if it is possible a safety thing?
    once i get my secondary VE dialed in, im going to use a spreadsheet i found over on ls1tech to recalculate my primary ve and then scale the maf to get everything back inline.
    Nov 2004
    Houston, TX
    140
    Quote Originally Posted by ixc
    hmmm the paste special acts up for me once in awhile too, but I don't have any problems with the 90 kpa row... ??? As far as the way you are tuning, that's the exact way I did it too and it does interpolate, but even through the smoothing function you can see that it will naturally interpolate. I got flamed a little at first for tuning the secondary only but I really think it's a good idea since obviously data is being created in the histogram whether certain rows are missing or not. Eithery way though, doing the primary first as opposed to the secondary still probably yields a close enough result. I just like manipulating data that i know I'm dealing with
    And then...
