Howdy,
I have ordered my EIO from HPTuners(I got sick of messing with LTFT's+ STFT) and dont want to hire a dyno at probably the cost if not more of buying a WBo2.
Ive ordered the Techedge Wideband (2A0) o2 Kit (yes kit , yes it takes ages to put together for a novice like me but it IS possible).
Ive free-to-air calibrated the wideband unit and im getting some o2 bungs put in the exhaust. Yes, i said BUNGS. Im getting one bung thrown in each bank as most of my logs show bank1 runs richer than bank2, im not sure which one to go by , so for the limited hassle, i'll try and use both banks and even out the results.
My real question is, how do some/all of the wideband units connect up to HPTuners EIO Interface. I can only find limited information (via searching) on what WBo2's are even supported and even less information on how they are connected up to the EIO. (Maybe a sticky needs to be created for supported WBo2 Types and how you connect them !).
My EIO should be in the post tonight, ive got my o2 kit all done and ready, but what connects the two ?? If it reads via the serial from the TE 2A0, then i need to get another usb->serial converter for my lappy, if it runs from *some* wire on teh TE 2A0, where do i run it from etc ?
If this info is somewhere else, im happy to go read another link
Ross
