Page 1 of 5 12345 LastLast
Results 1 to 20 of 85
Thread: 2.22 with net framework checks removed
    28,319
    http://files.hptuners.com/VCMSuite-2_22_NoLC.msi
    Our Signed Drivers can be found here http://www.hptuners.com/forum/showthread.php?t=5228
    For those that are getting a net framework error when trying to install 2.22 from your disk use this link.
    For those customers that are still using the old serial interfaces(Start with 0000) use MSI edit to delete the net framework check in the installer, msi editor & instructions on how to do this can be found here http://www.hptuners.com/forum/showpo...6&postcount=22
    Because serial interfaces stored the licenses in the software it is imperative to use YOUR software and not the MPVI software that is posted in this thread.
    Dec 2004
    Laurel, MD
    1,020
    thank you, this has been getting seriously annoying on the newer platforms
    May 2010
    Worked for me.
    Thanks.
    Jul 2009
    16
    Is there a beta version(2.23) with this removed?
    2009 White Pontiac G8 GT
    Stock for now
    1997 Pontiac Formula M6 *SOLD*
    Stroked Sprayed 6 Speed
    2006 Yamaha R1 Raven*SOLD*
    520 Chain +2 in the Rear.
    28,319
    Quote Originally Posted by WhiteHotG8 View Post
    All the new beta's do.
    Jul 2009
    16
    Good to know thanks.
    Stock for now
    Aug 2010
    Denham Springs, LA
    12
    The link worked for me, although my virus scanner is going nuts over VCMEditor.exe
    Jun 2008
    Charleston, SC
    969
    is this link for this issue?
    Uploaded with ImageShack.us
    Jun 2008
    Charleston, SC
    969
    Nope, still does it..
    28,319
    Quote Originally Posted by carlrx7 View Post
    We haven't been able to recreate this so are pretty sure its just a computer specific issue. Until we can recreate it consistantly we won't be able to fix it.
    -Bill
    Jan 2005
    18
    -Bill
    I've been having an identical issue. I just re-installed my entire laptop to see if it solves the problem since there is no way to re-install .net 2.0.
    Jun 2008
    Charleston, SC
    969
    i reinstalled win 7 for the 3rd time, and now it seems to be fixed.. dunno...
    Dec 2007
    776
    Thanks to you and the programmers on this one! Its been a PITA for a while now.
    If you run Win7 you need to right click the exe files ("VCM Editor.exe" and "VCM Scanner.exe" and run it in "windows XP SP3" compatibility mode. That fixes the issue above when you try to open or save files.
    Sep 2009
    Angola NY, (Buffalo)
    202
    Quote Originally Posted by IndyPete View Post
    That worked for me, thank you!
    Even after downloading the fix from Bill.
    I thought I was fubared, thanx to avast and it's false positive Trojan.......BS.
    All i did was rt click, proprieties, compatibility. done
    The Regal has been laid to rest..... rust
    Now have an 06 Lucerne with the 3.8 and wishing HPT would cover that car
    Loved my 2001 Buick Regal GS.
    With more than 334,000K, 3.4 & 3.6 pulley, Change stats and pulleys with the seasons, Upgraded grounds & power wire, Volt booster, Caspers timing commander(AKA happy knob), Spectra intake-fender wall, PLog, 3" DP & 2.5 exhaust, HPTunner 12" Impala duel piston front brakes, New trans,GMPP suspension... yada, yada...
    Tuner homebuilt's Avatar
    Dec 2009
    Southwest Florida
    81
    I am having the same problem. It left me without the ability to tune for weeks while I was trying to figure out how to fix it.
    I ended up rebuilding the computer. It worked for a bit but now it is doing it again.
    I tried the link but it still does it.
    Norton antivirus also thinks that dw20.exe is a virus. I found an option to tell it to restore the file but that didn't seem to help.
    I'm trying to let windows update the Microsoft net framework now to see if that will reinstall the missing dll.
    Any help would be greatly appreciated.
    Mar 2009
    Texas
    39
    seems like that link worked for me
    07 ss/?. Turboed LSJ
    Dec 2009
    Southwest Florida
    81
    Maybe I have to reinstall the OS again. HP Tuners seems to be the only application giving me trouble.
    This link as well as every other link trying to access a files.hptuners path is not working. Logged on here to try and download the latest to see if the Win7 issues where fixed, I tried about a month or so ago and never did get it working.
    Sure would be great to be able to use this software I payed hundreds of dollars for again.
    Looks like the downloads are working again.
