This will be great!!!
2018 GMC Denali A8 6.2L
2016 CTS-V
2016 C7 Z06 A8
2016 C7 Z06/Z07 A8 vert
2015 Chevy SS 6.2 LS3 A6
1996 Impala SS LT1 CAI
1995 Chevy 1500 5.3 CAI Z06 cam
1957 Chevy vert
Thanks a lot Chris.
Black 09 G8 GT Black 09 G8 GT RPM tuned, Baby cam, Vararam, Kooks LTH, Stock muffs, Circle D stall, RPM ported TB and Intake, UDP, PCM for less trans cooler,BMR toe rods trailing arms and diff bushings, First G8 GT with a Camaro 3.45 diff swap(as far as I know)421whp 384wtq [email protected] pre gear swap
the new params have been added, they will be in the next release. Please contact support to be notified.
I count sheep in hex...
Probably a week or so.
Thanks Bill.......Cant wait.......
Scott (Retired Navy)
Paralyzed Triathlete
2010 Camaro 12.35 110.73 1.65 60ft
Mongillo Motors
Speaking of a new beta, have you fixed the bug yet regarding the line pressure table for the 6L80? It's the one where if you change any values in the Trans->Auto Shift Properties->Shift Pressure->Shift Pressure Other->Max Line Pressure table it stores incorrect values and you run the risk of blowing your trans?
Thanks, I've resent it. Its a software design bug, not an engineering bug so Chris really has nothing to do with it.
Hurry up! I want this
Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
618/618 motor
906/862 spray
Caterpillar 50 Forklift- Duramax swap
Chris, Bill, is it in downloadable format yet?
Mongillo Motors
not to my knowledge.
ttt
Mongillo Motors
da bump...
