Results 1 to 20 of 35
Thread: single cylinder misfire on TT setup
    Hey all,
    just thought I'd check in if anyone might have any ideas. I'm tuning a 2005 C5 with a 427ci motor/AFR heads. Car runs a TTix turbo kit with 62mm turbo's. Method of tuning is a newer style maf card with everything /2 as necessary and the tune seems to be working out well. 8 - 9 psi on a 90f summer day netted about 700whp. Although there is a lot of room to turn up the wick on power, we have a misfire issue which is yet to be solved and am hoping some of the experience on this board might help solve the issue.
    Misfire only happens under heavy load (3rd gear and up) with boost. Only on cylinder 6. A hard run could produce up to 60 misfires (meaning it's not each and every ignition that misfires, but enough as it should be zero). We have checked compression and leakdown numerous times. We have checked cam lift on that cylinder, plug gap, plug, wire, coil, injector, low imp inj driver box, harness, etc (each of those components have been eliminated by removing and substituting another part). I finally got down to feeling it is a lean misfire on that cylinder. Motor uses a fast92. We took off the fast92 and installed a stock LS2 intake manifold and the misfire left cylinder 6 completely and started on #1. That is where I am currently at.
    Any suggestions?
    Much appreciated.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Is your timing erratic in the area it misfires?
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    steady 18 dg. Thanks for chiming in
    Aug 2010
    Roswell, N.M.
    1,956
    Weird.... Alot of the LS motors that run Prochargers just flat out start lacking ignition power, but it's on multiple cylinders, not just one. Possibility though, the vacuum line from the intake to valve cover on either side could be pulling oil from the cylinder heads and back into the intake, thus traveling into a designated cylinder at WOT causing a misfire.
    618/618 motor
    906/862 spray
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Swap injectors around, and see if the misfire follows the injector. That's the only thing I could think of since you said changing intakes (which meant the injectors were removed and reinstalled) moved the misfire.
    http://www.dsxtuning.com
    Just say no to bull s***.
    thanks Dsteck,
    we've swapped inj 3 times now with no change. I'm actually wondering if it's possible that there is a charge pipe leak causing high backpressure. Any more suggestions are welcome.
    Mar 2008
    St. Louis, MO
    4,863
    You could try changing the gaskets for the intake manifold around. Swap the misfiring cylinder with a good one. That's the best thing you can do... just try swapping parts with known good ones, one at a time, and see if it follows a specific part.
    Aug 2010
    Roswell, N.M.
    1,956
    My suggestion: This sucks. ok let's get back to basics. What on an LS engine detects misfire?
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Also you said you're running AFR heads. Not quite sure what that means, but are they shaved? Say the heads sit differently on the block than stock. Should the actual geometry be changed of how the heads/block/intake sit, than it's highly possible that you have a leak on the underneath side of the intake ports from the intake manifold as the gasket wouldn't mesh correctly. It's a long shot, but I've seen it happen before, and since the actual intake manifold changed which cylinder is misfiring than you have to account for variable different flaws in design and structure.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    Quote Originally Posted by IDRIVEAG8GT View Post
    The gaskets will take up a lot of slop.
    Aug 2010
    Roswell, N.M.
    1,956
    I Understand that, but is it not a possibility? I said it because it only happens under heavy load (maximum boost, and cylinder heat)
    618/618 motor
    906/862 spray
    Tuner Street Legal's Avatar
    Mar 2007
    Houston, TX
    162
    what's the sprak plugs gap ? it could be a spring issue.not a tune issue. any leak or gasket issue will be felt under regular driving conditions.either trims or map readings will show you that.and does that car backfire when cyl 6 missfires ? if it does then you aren't getting any spark there.
    you could remove the discharge pipe and try to run the car N/A and see if it missfires.
    Mar 2007
    Houston, TX
    162
    if it sucks oil from the valve covers to the intake the car would smoke it and it would reach most of the cylinders not possible to get in one cyl only.missfires under a boost is mostly related with ignition systems , coils,wires,plugs ,otherwise a bad valve spring
    street legal, interesting you mention that. The customer has the odd backfire up top at high rpm. I'd bet that happens after a high misfire count. This has always been my guess. I'm betting on a lean misfire but have a feeling on what it could be. Hopefully will have some info tomorrow.
    Tuner Mez's Avatar
    Nov 2008
    Austin, Texas
    163
    I helped find a misfire on a 7.0L S/C that eventually dyno'd at 809 rwhp. It was traced it to a broken wire to the fuel injector. Actually, the wire was broken in two spots near the connector at the injector. The insulation on one of the breaks looked fine.
    Could be anything on that cylinder. Make sure the compression is fine then look at wires, plugs, etc. Swap between cylinders to test.
    2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Street Legal View Post
    This is true. I'm just suggesting. But per smoke and what not, this all depends on the volume of oil to enter the intake. A minute enough amount of oil would barely show smoke, but could cause a Misfire depending on Weight/Temperature/Synthetic/Conventional/etc.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    I have an idea now because of a past event that happened to me. What kind of spark plugs are you running? Please tell me they are NOT E3's. If they are, yank them all out and shake them and watch to see if the porcelain rattles up and down inside the plug. E3 went through several lawsuits for defective plugs in which the porcelain separates from the body and would eventually break at the end and the pieces destroy your engine. I've been there and done that and have the proof to back it.
    618/618 motor
    906/862 spray
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Quote Originally Posted by icicleboy View Post
    thanks Dsteck,
    How about turning up the dwell on the coils? Stock dwell settings will give those coils 300,000 miles of service. You can run up to 9 msec on them but the longevity goes down quickly above 6 msec. At 9 msec you will get about 20K out of them.
    Always Support Our Troops!
    TR6's gapped to 0.030. My gut is telling me that it's a bad boost leak causing extremely high backpressure in the exhaust manifold which could cause a misfire.
    Springs on that cylinder have been checked. I'm also going to do as advised and swap some injector harness stuff around to see if that cylinder has a bad wire to the inj that only shows up at load.
    Thanks so far everyone!
    EC_Tune,
    thanks for the suggestion, that was my first course of action and it made no change at all. I incremented everything from 12 - 16V by 1ms per reflash until I was just over 6. No change.
