Wheres my power at? Car certainly is being held back somewhere..
Vehicle: 2002 C5
AFR 205 heads milled 0.030
Cometic Gaskets
Z06 MAF
Blackwing Intake
Comp Cams 222/222 581/581 +4 on 115 LSA
VE tuned dead on via wideband method, wideband in car...
MAF scaling is right.
I Still have stock injectors, which i know should be getting close to maxed out with this setup. The wierd thing is that the car is running/scanning very inconsistent. I even disabled all fuel trims (i have a wideband to verify A/F so I am not concerned) and the car is still performing inconsistent.
For example, tuning it tonight i was first hitting 13.5 A/F @ 5500 RPM with the injectors running at 17MS (faily high duty cycle)
After fattening up power enrichment it is maintaining 12.56 A/F with the injectors at 16-17MS.. how did the duty cycle not go up? "This can only mean the car is making inconsistent power.
Another oddity is that even with A/F ratios tuned and confirmed the same, same timing, etc, the car will run alot faster in SD mode than with the MAF enabled (even putting out the same a/f). I am seeing no knock retard.
Its 66 degrees outside and with the MAF enabled the car is barely spinning the tires in 1st gear. However, earlier with SD at the same A/F ratio and timing the car was roasting the tires on command.
Is there some sort of blockade to power thats kicking in that i haven't disabled in this tune? I know with the good amount of timing im running and the flow of these heads the injectors should not have so much more headroom at a 12.5 a/f.. (i still cant explain how @ the same duty cycle they were 13.5 a/f before as well). The wideband im using has been tested, swapped out and verified so i can rule that out. I'm pulling my hair out over this car, it feels barely faster than a Stock Z06 the way it is now.
Please take a look at my BIN for any errors before i start considering a mechanical issue at fault here. http://supercartuningcenter.com/tuning.bin
