Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: 2 bar map for 3800
    7
    Re: 2 bar map for 3800
    I don't have hptuners (I'm waiting on 2.0 with USB), but what I am expecting out of the software is be able to tune for LT1 MAF and 36 lb GTP injectors. This should up the top of the range where the computer is delivering measure amounts of fuel to air from approximatly 250 hp to approximately 475 hp. This would be over a bar of boost, so why the need for a 2 bar map? (although using GTP parameters up to the 1.4 bar limit would make sense).
    I am I missing something here?
    MAP sensors are specified in absolute terms.ie.
    1 bar = ~105kPa = atmospheric = 0 boost (0 PSI)
    2 bar = ~210kPa = atmos + 1bar = 1bar boost (~15 PSI)
    3 bar = ~315kPa = atmos + 2bar = 2bar boost (~30 PSI)
    so although you have a "2bar" sensor it only reads up to 1bar of boost (15 PSI).
    Chris...
    I count sheep in hex...
    May 2004
    FWB Fl
    299
    Quote Originally Posted by Chris@HPTuners
    Chris...
    i dont plan on running much more the 15 all that offten so that would work alot better for me............. i just need to know if it works in our car/ pcm in stockerish form
    AKA what do i need to do to make it work like we need it too ?
    http://www.turbov6camaro.com
    1997 Stalled V6 Camaro
    Goal: 10.99 in the 1/4
    Goal: 100 MPH (completed)
    Best Dyno: 456 RWHP and 509 RWTQ
    Best: 1/4 mile 11.23 20 PSI
    Best1/8: 7.18 @ 99 1.83, 60 foot 20 PSI
    28,311
    2 bar definitly wouldnt work as it stands...they would need to rework the os's like stated...now the 1.5 bar the gtp's use might work...that im not sure about but even that only goes to like 8-9psi before you max ou tyour ve table.
    May 2004
    FWB Fl
    299
    Quote Originally Posted by foff667
    yes but it maxes at 105 now at least it would be good till 140 mark
  6. #26
    7
    Quote Originally Posted by RGB
    Why the need for a 2 bar MAP if the HPtuners lets you use an lt1 MAF and 36 lb (or more) injectors?
    So the stock MAP reads the same from 0 to 15 psi of boost, what is that hurting if the upgraded MAF is measuring air correctly?
  7. #27
    May 2004
    FWB Fl
    299
    i'm taling about the Fbody
    the maf maxes at 11500 Hz no matter what (even if i set the lb/min to 80 min max it still maxes. and would cut IPW in half when it did, we got that to stop but the maf is still going to max out and after that there is no way to add fuel to my car other then dumping it in th PE table and that's shooting in the dark
  8. #28
    7
    and I'm talking about upgrading to the lt1 MAF (which won't reach 11,500 Hz until 471 g/s [62 lb/min] (way more than the 170 g/s stock MAF limit) on the 3800 f-body
  9. #29
    May 2004
    FWB Fl
    299
    why use lt1 when we could use LS1 ?
  10. #30
    email me your bin and i can add the maf fail freq for it.
    that way at least your MAF will stay on the last value in the table and you can adjust the fuel to keep the mixtures right.
    Chris...
  11. #31
    May 2004
    FWB Fl
    299
    [quote author=Chris@HPTuners link=board=gmv6engine;num=1125271198;start=20#29 date=09/09/05 at 19:15:18]email me your bin and i can add the maf fail freq for it.
    Chris...you did that for me already
    so what should i do to make sure i got the fuel i need then ? put it at like 80lb/min or something ?
  12. #32
    7
    The f-body lt1 MAF:
    uses the same 3 pin connector as the stock V6 MAF
    and
    more g/s air then LS1 MAF (428 g/s?) at 11,500 Hz
  13. #33
    Quote Originally Posted by Turbo V6 Camaro
    lol, so many emails
    once the MAF reaches the max point the easiest way is to use the PE table to richen the fuel up.
    Chris...
  14. #34
    May 2004
    FWB Fl
    299
    lol, so many emails
    Chris...
    cool that what i have been doing
  15. #35
    Advanced Tuner devildog9999's Avatar
    Feb 2005
    Niagara Falls, NY, USA
    354
    I have been looking into the aftermarket turbo kits for the 3800, and I have not seen any mention of a new map or maf sensor in any of the kits...they DO however have a custom PCM shipped with the kit.
    What exactly are they "customizing" that allows for over 20 lbs of boost with no mods to any of the sensors?
    Regal GS Site Owner / HPT Moderator / FTV6 Mod
  16. #36
    May 2004
    FWB Fl
    299
    Quote Originally Posted by devildog9999
    they probly stop the maf from maxing and richen up the fuel with the PE table like i have have
  17. #37
    Oct 2004
    35
    What alot of people are using are AFC's to part out the signal of the MAF so they don't quite max it out.
    I wish hptuners had the capability of 3bar but we're testing out 3bar capability on my GTP as we speak.
    I won't be able to edit my fueling myself though which sucks.
  18. #38
    May 2004
    FWB Fl
    299
    Quote Originally Posted by Overclock_This
    why is that?
  19. #39
    Oct 2004
    35
    why is that?
    It's going to be done using actual hex and another tuner.
    If Hptuners can't support 3 bar, I don't think i'll be able to edit it.
  20. #40
    May 2004
    FWB Fl
    299
    any updates
Similar Threads
  1. SD tuning for E38/E67 ECM's
    By Chris@HPTuners in forum GM V8 Tuning - Engine, Gas (Gen 4)
    Last Post: 05-19-2022, 05:15 PM
  2. 3 bar map with 2 bar tune?
    By kwiktsi in forum GM V8 Tuning - Engine, Gas (Gen 4)
    Last Post: 05-18-2007, 11:13 PM
  3. 2 Bar Os Map Pid
    By FlaBouy in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 04-29-2007, 12:58 PM
  4. Question about 2 bar map SD tuning
    By mike72678 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 09-15-2006, 08:47 PM
  5. ATTN: soundengineer! Fooling the ECM w/ a 2 or 3 bar MAP sensor?
    By txoutlaw in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 01-03-2006, 11:12 AM
