I just upgraded to the 1 bar enhanced OS so I could have a VE table to work with but it's all 0's. Anyone have an idea of what to start out with. Better yet a tune I could copy and paste for a starting point?
05-06 GTO or 05 Corvette VE table is a good starting point.
Here's something I whipped up, this is from a 2005 Corvette
Min map of 15kpa, max of 105 then just interpolate between the two and plop in the values in the txt file
Should I also disconnect the MAF when tuning in SD?
Thats what SD tuning is all about.
Yup already making serious progress! So should I disconnect the maf or leave it or it doesnt matter?
If the iat is integrated I would leave it connected.
Well for some reason it says I have the 2 bar enhanced. I don't know how that happened.
Yeah its all the same, you can use it for 1 bar, 1.2 bar, 2 bar, 2.5 bar, etc. Its an all inclusive operating system. For that matter you could even use the maf sensor if you wanted.
