![Quote](images/misc/quote_icon.png)
Originally Posted by
guardsman01
What happens if I have to change the PCM (accident, whatever)?
Will I be able to use the edited flash files for the old PCM on the new one, or will I have to download the stock files off of the new PCM, and edit those?
If I have to download and edit the new files, is there a function to "cut and paste" data from edited files to new ones?
Also, does the possibility of corrupting data during a download increase the more you re-flash the PCM?
I mean, I know the more often you do it, the greater chance of it happening, but does the actual EEPROM itself become more susceptible to errors while writing as the number of times it's been reflashed increases? Does it wear out, I guess would be a way to put it.
Thanks.
