I have Texas Speed 5.3 heads and 224R cam in LS1 Corvette with Manual transmission. AFR is 12.5 at WOT and I'm getting a lot of knock retard. PCM is taking away as much as 10 degrees timing. I started with stock tune which had about 26 degrees of timing at WOT and have steadily reduced timing in about five different steps. Last run I set timing to 16 degrees at WOT. It doesn't seem to matter what the timing map is set at, the knock retard is always removing about the same thing 10 degrees.
Could it be that the knock sensors are too sensitive?
