While many of you are aware of this, I am also acutely aware that many are not, so this is for the group that is not. Throughout the past few years, I've had many discussions with friends and various forum members about widebands. There is a lot confusion about how this works so I figured I would post up my .02 on the subject. The misunderstandings all seem to be relatively the same and when a misunderstanding exists, the person thinks they should be looking for different stoich values on the display when they deviate from pump gas, or change the target because they have a percentage of ethanol in their pump gas. This is not the case. If you run Methanol, E85, E100, Propane, or CNG, you will want to see 14.7:1 on your wideband display. The wideband is designed to take the sensor voltage that is equal to Lambda 1.0 value and convert it to the number that represents stoich for pump gas, 14.7:1. If you empty your tank and fill it with Ethanol, you would change your Stoich value in your Fuel>general tab to whatever you agree stoich actual is, be it 9.7-9.9:1. Doing this will multiply your actual yielded injector pulse width by whatever is necessary to achieve that actual true AFR. In other words if you went from pump fuel with a value of 14.68 in that position and you changed to E85, placing a 9.9 value in there, it would multiply your resultant pulse width by 1.48 without changing the values in the VE or MAF. If you want a .85 lambda at WOT with your alternate fuel, you would look to achieve a 12.5:1 on your wideband display. All the wideband is doing is taking a sensor voltage that equates to a specific lambda and displaying a value that is appropriate for gasoline. The sensor has no idea what your actual AFR is. It is only counting oxygen content in your exhaust in an attempt to provide feedback on your AFR. The resultant display is not a fact. Why? Because many other factors will skew your values. Bad plug wires, plugs, detonation, a bad injector in one cylinder can alter your reading by a proportional amount, making a tuner think they are slightly lean. This is why I like to still view the narrow bands. You can see when one bank is having trouble at WOT. It is important to keep in mind where your sensor is placed when tuning. Most of the cars I tune have the wideband sensor placed before the X pipe, so it only picks up one bank. I've also seen the wideband bungs placed so early in the collector that I would expect one specific cylinder to have a huge emphasis over the remaining 7.
