List of parameters?
Does anyone know what list of parameters I should be able to see in Editor? I notice that there is a lot of which there is nothing in there.
Mitchell
'04 Supercharged MC SS
MOD LIST
Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
what you see is what you get...
I think he wants to know which ones actually work. A good portion of the listed sensors and PIDs don't work. Like Oil Pressure, Cyl Airmass, etc.
I think he's talkin' about things in the editor, not the scanner.
Anyways, check the help file. You should see screenshots of each item available. Some will say V6's only. I don't think there is an official list though.
All Motor 2001 GA GT1
Mitchell
MOD LIST
HP Tuners Owner
open the Navigator view, right click and select expand all.
Thanks Chris! So this is the list that my V6 supports?
Mitchell
MOD LIST
Nice. Thanks Chris (I never use the Navigator view).
This would be the parameters available to your V6, assuming you have your V6 bin open (open a vette bin, and there will be some different ones)
