I've been fighting a very limited part throttle popping. I never seem to be recording when it happens. Tonight, it made me wonder if I have my parameters to enable PE too high (i.e. the popping is because it's too lean and not in PE). Would you mind sharing?
MAP: 70 kPa
MAP Hyst: 6 kPa
Enable RPM: 2,000 RPM
RPM Hyst: 20 RPM
Hot PE TPS: 45% 0-2,000 RPM, 30% 2,500+ RPM
PE Delay: 4,000 RPM
